1992 ford explorer XLT (help)
This is a discussion on 1992 ford explorer XLT (help) within the TECH Discussion Forum forums, part of the TECH Discussion category; ok i own a 1997 s14 k's aero but this aint about the car its my lil bro we cant ...
Old 05-22-2004, 03:03 PM   #1
DRIFT_BUNNY
DRIFT_BUNNY's Avatar
ok i own a 1997 s14 k's aero but this aint about the car its my lil bro we cant get his explorer to turn on.
.its been sitting for 7 months
.has a full tank of gas from 7 months ago
.cranks a turns on for 1 or 2 seconds
.new battery added
thats it i cant think of anything that can be wrong with it because last time it was on it work just find.
im going to empty out the gas and add a fuel injector cleaner just for the heck of it. but i need help!
DRIFT_BUNNY is offline   Reply With Quote
Old 05-22-2004, 03:09 PM   #2
RallyGT
Domestic Drifter
RallyGT's Avatar
Send a message via AIM to RallyGT
yes...get rid of that old gas...through time gas looses the chemical needed to run a car. 7 months should do it. syphon out all the gas and run an engine cleaner fluid through it. then put in new gas.
RallyGT is offline   Reply With Quote
Old 05-22-2004, 03:51 PM   #3
Chas
Chas's Avatar
I know the problem, we had the same problem awhile back. Its a Ford!!!!!!
No really, try some fresh gas, look at the injectors, sprarkpulgs, you know, the basic stuff.
Old 05-22-2004, 06:20 PM   #4
Drift For Food
OMG the ground's white!
Haha, I second the Ford problem.
Yeah, gas can go bad. 7 months? Eh, maybe. I'm not sure how much you tried starting it, but it may take a little bit of effort if it's been sitting that long. Some fresh gas will definately help though.
Old 05-23-2004, 04:22 AM   #5
chrisfromda909
yeah run it for a while to purge all that old gas from it. when i had my honda, before i put new gas in it, it would diesel after i shut off the car because the gas was so shitty. so yeah new gas and add cleaner.
Old 05-23-2004, 05:53 PM   #6
Tighty_wh1tey
Junior Member
Tighty_wh1tey's Avatar
if its been sitting for that long id reccomend an oil change new plugs and all that crap too.
Tighty_wh1tey is offline   Reply With Quote
Old 05-24-2004, 07:33 AM   #7
mranlet
mranlet's Avatar
Your gas may have turned sludgey in the injectors and rail (if you're unlucky). Worst case scenario, you may need to replace the injectors, but 7 months isn't that long. Try the new gas and see what happens.
Old 05-25-2004, 01:06 PM   #8
NsLegacy
if that doesnt work, it might be that someone hit the kill switch under the passenger dash. i had this happen to me once and it seems that all fords have it. i guess just in case u get in an accident it shuts the engine off. i forgot where it was exactly, but it's only a switch. that might be ur problem too, not sure.
NsLegacy is offline   Reply With Quote
