FC na 2 turbo
This is a discussion on FC na 2 turbo within the TECH Discussion Forum forums, part of the TECH Discussion category; I got an N/a FC and was thinking about turboing it, i know i would need the OEM turbo to ...
Old 05-29-2004, 10:32 PM   #1
Cobra_R
Cobra_R's Avatar
FC na 2 turbo
I got an N/a FC and was thinking about turboing it, i know i would need the OEM turbo to do this then go aftermarket and was wondering, besides the OEM turbo, what other OEM T2 parts would i need to put into it to make it run turbo without any problems. Would i need the T2 tranny, etc, etc.
thx
Old 05-30-2004, 05:24 AM   #2
Jin13b
Team Infini Style
Jin13b's Avatar
Send a message via AIM to Jin13b
Youd need to do a lot of custom work, theres a write up of whats needed at rotary ressurection, http://www.rotaryresurrection.com/turboconversion.htm
I wanted to do the same thing a while ago until I read that. It'll probably be easier just to swap a TII engine in it. No one makes a bolt on turbo for the FC's yet, but I heard one place was working on it but I dunno if they still are. Hope that helps
Jin13b is offline   Reply With Quote
Old 05-30-2004, 08:53 PM   #3
TP | sil-beer
TP | sil-beer's Avatar
Send a message via AIM to TP | sil-beer
just go j spec
TP | sil-beer is offline   Reply With Quote
Old 05-30-2004, 09:56 PM   #4
turbo23
Send a message via AIM to turbo23
it would be easier to just buy a t2 but if want to, buy a t2 engine and put it in, u will need a t2 ecu as well, u can run a stock NA tranny, but a t2 tranny is prefered since they are hella strong.
turbo23 is offline   Reply With Quote
Old 05-30-2004, 10:12 PM   #5
ToplessFC3Sman
ToplessFC3Sman's Avatar
if your switching in the T2 engine, do the tranny too, just less problems in the future. The NA trannies are the same as in the FB's and SA's, which are lighter cars than the FC's, with less power. Putting the same transmission from a lighter car with less power into a heavier car with more power can cause problems to begin with, dropping in an even stronger engine will make that much worse. My advice is go with the T2 tranny if your doing the whole engine. Possibly even the whole rear end while your at it, you gain an LSD in the process
