240sx gas tank leaks
This is a discussion on 240sx gas tank leaks within the TECH Discussion Forum forums, part of the TECH Discussion category; Dang...this is the second time it has happened to me. My gas tank is leaking... It's very weird i still ...
Old 07-07-2004, 12:12 PM   #1
SilviaLove
UrbanKnights
SilviaLove's Avatar
Send a message via ICQ to SilviaLove Send a message via AIM to SilviaLove Send a message via Yahoo to SilviaLove
Question 240sx gas tank leaks
Dang...this is the second time it has happened to me. My gas tank is leaking... It's very weird i still don't know what i hit(I was told i hit something the last time), never even felt any major bottoming out. My s14 isn't very low either, I have springs that are rated for a 1.25" lowering. I was wondering if any of you 240 owners ever had this problem? When this first occuried, two years ago, I didn't see any FAQ on sites such as 240sx.org or anyother post on other sites, and now that its happened again i wonder if this has happened often, chances are that it doesn't. I'm guessing this could be what some people call bad luck.
SilviaLove is offline   Reply With Quote
Old 07-08-2004, 01:17 AM   #2
180fan
Do you have a more specific location than just your gas tank? There are a few lines up there that could be leaking unless it's your gas tank specifically. There's a return, high pressure, vapor relief, fill, and one other hose up there but forgot what it was for. Check those, I had a leak on the vapor relief hose that caused gas to literally pour to the floor. I fixed that, and that was after I had replaced all the regular hoses with fuel injection approved gates fuel lines.
