FC problem.
This is a discussion on FC problem. within the TECH Discussion Forum forums, part of the TECH Discussion category; When I start my FC i have to pump it, while it warms up, it will idle fine at 1100 ...
Old 07-08-2004, 07:05 PM   #1
defiantfc3s
Defiant Drifter
defiantfc3s's Avatar
Send a message via AIM to defiantfc3s Send a message via MSN to defiantfc3s Send a message via Yahoo to defiantfc3s
Question FC problem.
When I start my FC i have to pump it, while it warms up, it will idle fine at 1100 RPM. After it warms up it will start idling lower and lower. Then I rev it up to about 2500 and keep it there for a second, but when I let off the accelerater the RPM's will fall back too about 200 and then eventually quit.
I have checked the fuel pump, fuel lines, and injectors but nothing was wrong with any of them. Anything I might check?
defiantfc3s is offline   Reply With Quote
Old 07-08-2004, 08:01 PM   #2
theflatlander
theflatlander's Avatar
check all vacuum lines, and or adjust you TPS, you also might want to check your compression.
Old 07-08-2004, 08:33 PM   #3
Ripper
post whore
Ripper's Avatar
Re: FC problem.
taht's pretty high idle. my car idles at about 4-800RPM
Old 07-09-2004, 11:10 AM   #4
defiantfc3s
Defiant Drifter
It's a high idle because I adjusted it to be higher, and the stock idle position is 900 RPM.
Old 07-09-2004, 12:04 PM   #5
turbo23
Send a message via AIM to turbo23
stock idle speed is 750, u could have a bad compression> But check all your vaccum lines just to be sure.
turbo23 is offline   Reply With Quote
