S13 crankshaft vs. S14 crankshaft
This is a discussion on S13 crankshaft vs. S14 crankshaft within the TECH Discussion Forum forums, part of the TECH Discussion category; are these the same. I found one out of a S13 redtop and I need to put it in my ...
Old 07-23-2004, 12:01 PM   #1
TX Drifter
TX Drifter's Avatar
are these the same. I found one out of a S13 redtop and I need to put it in my S14 engine. Will this work? Just want to make sure. THanks for the input guys!!!
TX Drifter is offline   Reply With Quote
Old 07-23-2004, 12:03 PM   #2
Ernie
High Speed Magician
Ernie's Avatar
Send a message via AIM to Ernie
Yes it will work...but you have to match the stamp numbers and get the right bearings, good luck. My engine uses an NA S14 crank. Makes 400hp.
Ernie is offline   Reply With Quote
Old 07-23-2004, 01:16 PM   #3
TX Drifter
TX Drifter's Avatar
thanks alot Ernie. where is a good place to get bearings?
Old 07-23-2004, 07:38 PM   #4
Ernie
High Speed Magician
Ernie's Avatar
where do you live?...if you are in SoCal area, then go to Superior/Puente Hills Nissan and talk to Mikey. He can get anything having to do with SR20s or RBs or whatever. Like I said before you will want to consult your FSM(factory service manual) before you order to determine which bearings you will need and check your stamps on the block and the crank.
Old 07-23-2004, 07:39 PM   #5
Ernie
High Speed Magician
Ernie's Avatar
Actually any Nissan dealer should be able to get the bearings. You need the numbers though.
