This is a discussion on Toyota Corolla Difference within the TECH Discussion Forum forums, part of the TECH Discussion category; Ok so i'm seeing some AE86's on here. I take it there rwd right ? Is it a special model ...
Thread Tools |
Rating:
Display Modes |
Toyota corolla difference
Is it a special model corolla? I found a few of them for extremely cheap in my area and i'm just wondering . Thank you for the help -Matt |
84-87 sr-5/gt-s only
Pro Drift Watcher
i also have a question about the corolla...
are the GTS and SR5 the same Chassis? i heard they were diffrent chassis codes..... |
"Fear For Yourself"
I believe they are the same chassis, but the GTS has lsd, and some other stuff the SR5 doesen't have, while the SR5 was the base model. I think this info is correct.
#5 | |
on a side note they have diff drive train, motor/ rear end, same tranny, same chasis its the vin that is diff, sr-5 vin starts with ae86, gtsvin starts with ae88 |
the main things are that the sr5 has a crappy sohc carbuerated engine and rear drum brakes, unless you plan on swapping the engine stick with the gts
SR5:
Front engine, rear wheel drive Rear drum brakes, carbed motor, open diff Basically a commuter car that get good gas mileage, and is very reliable. GTS: Twin cam TVIS operated 16V engine Close ratio manual transmission oil cooler Factory option limited slip differential 7500 RPM redline Front and rear disc brakes Stiffer suspension, thicker front and rear sway bars Basically a commuter car chassis on crack. Has features on it that are usually reserved for "upper echelon" sports/race cars. |
ACDSevenGuy
But yes, SR5 and GT-S both have the AE86 chassis.
whats the easy way of knowing the gts came with lsd? do you burn out and see if both tires rotated
lol..
iam not to sure my self but i dont think you would do a burnout
#12 | |
#13 | |
ACDSevenGuy
Newbie?
SR5 gets better gas mileage, uses less gas and what not.
To find if you have LSD on an AE86 1. If the numbers T283 are located in by the VIN on the bottom right hand corner of the plate on the firewall, right after it says T50, the car was originally equipped with LSD, if it doesnt have that but has T282 instead, the car never came stock with LSD (taken from hachiroku.net techref) 2. Do a burn out and see if you leave two patches. 3. look under the rear of the car and look at the diff, there should be a sticker that says "LSD OIL ONLY" on the back of it. 4. You could take it apart to be 100% sure. |
#15 | |
Touge only.
#16 | |
#17 |
Ok I'm going to hang my head in shame now..."e-m-i-s-s-i-o-n-s" I honestly didn't know that...
#18 | |
noob
