Driveshaft
This is a discussion on Driveshaft within the TECH Discussion Forum forums, part of the TECH Discussion category; Will I need a special Silvia driveshaft if im swapping in a SR20DET and doing a manual conversion? (in an ...
Old 07-26-2004, 09:51 AM   #1
bboyt3nsk
Dinosuars=Jesus Horses
Driveshaft
Will I need a special Silvia driveshaft if im swapping in a SR20DET and doing a manual conversion? (in an 90)
Old 07-26-2004, 10:04 AM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
As far as I know, the SR20DET's transmission and the KA24's transmission are exactly the same from the end of the bellhousing, back. (Except for gearing) That means all you need is any manual driveshaft and you're good to go.
Old 07-26-2004, 11:00 AM   #3
bboyt3nsk
alright...would i be able to just get the fornt half of the driveshaft? or do i need the whoooole manual driveshaft?
Old 07-26-2004, 11:34 AM   #4
180fan
the front half is different for AT and MT's. Otherwise it should fit no problem between KA and SR IF you cut the SR tranny end cover thing or switch it to the KA one.
