Brake Discs: Drilled, Slotted, Both, or Neither?
This is a discussion on Brake Discs: Drilled, Slotted, Both, or Neither? within the TECH Discussion Forum forums, part of the TECH Discussion category; I love stopping. It's fun, and it prevents nasty crashes. However, some people seem to have some misconceptions when it ...
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Old 08-02-2004, 03:25 PM   #1
GRiDRaceTech
GRiDRaceTech's Avatar
I love stopping. It's fun, and it prevents nasty crashes. However, some people seem to have some misconceptions when it comes to performance braking. I'm going to describe each form of disc design and its upsides and downsides.
Blank
Blank brake discs have no dimpling, slotting, or drilling. They are just a clean, smooth face. The advantages to blank brake discs are that they have the most surface area, are very easy on pads, are the cheapest, and resist cracking very well. The disadvantage is that they don't have areas to expel gases. However, that disadvantage is pretty much a moot point considering most modern pads don't build up gases enough to create a skating effect. However, most of the time blank rotors are not available with directional vanes, which is sometimes a very big buying point.
Drilled
Drilled brake discs are essentially blank brake discs which have had holes drilled or cast into them. The cast holes will resist cracking more than simply drilling holes, but if the drilled holes are chamfered correctly no problems should be had. Also, buying a drilled rotor which has been cryo-treated is a good idea. The idea behind drilled rotors was to create areas for the gas which built up between pads to be expelled. Another bonus is a lighter overall disc, thus lighter rotating mass and less unsprung weight. The least important bonus is that they look blingin'. However, the disadvantages are: decreased cracking resistance, increased pad wear, decreased brake disc surface area, and higher replacement cost.
Slotted
Slotted brake discs are blank brake discs into which grooves have been cut. The grooves may extend in an arc to the outer edge of the rotor, or in straight lines. Advantages: less prone to cracking than drilled, usually cheaper than drilled, often have more surface area than drilled, lighter disc, blingin'. Disadvantages: increased pad wear, decreased surface area compared to blank. Often available with directional vanes.
Slotted and Dimpled
I can't see a point other than some people may consider them more blingin'. Buy 'em if you want, but don't pretend the dimples actually do anything.
Drilled and Slotted
Combines both drilling and slotting in one disc. Too much loss of surface area makes these bling-only. Almost every professional race team in the ALMS runs either drilled or slotted brakes. (Mostly SLOTTED[stupid me]) I'm fairly sure the combination was created for looks, not track-worthiness.
In the end, slotted wins. Slotted rotors will simply be the best for any street-based car. Coupled with good composite pads, they will offer the best fade resistance for lasting pedal feel and worry-free stopping.
If anyone wants to chime in with data or knowledge feel free.
Old 08-02-2004, 10:59 PM   #2
Emagdnim
400lbs Gorillia
Emagdnim's Avatar
How about the differences in the material of rotors. Alot of people think steel rotors are best and they would be wrong. While steel has a higher tensile strength, cast iron is many times stronger than disc brake requirements. Its thermal transfer characteristics are significantly better than those of steel so that the heat generated at the interface between pad and disc is efficiently carried through the friction faces to the interior surface of the disc and into the vanes from where the heat is dissipated into the air stream. Cast iron is more dimensionally stable at elevated temperature than steel and is a better heat sink.
I do beleive there are other more exotic materials being used for brake rotors(titanium) but I think cast iron is more then enough for any road car.
Old 08-04-2004, 07:00 AM   #3
jboss
what makes your car stop faster----short answer--better tires
read the definitive article http://www.wilwood.org/pulpfriction.pdf
or here
http://scirocco.dyndns.org/faq/brake...n/pfpage1.html
jboss is offline   Reply With Quote
Old 08-04-2004, 07:18 AM   #4
Tsunami
Tsunami's Avatar
Now the trend is toward slotted rotors. There have been some issues with the cross-drilled rotors. Although they look cool they can sometimes be prone to cracking in between the holes. The slotted rotors don't have this problem, and they still serve to ventilate the rotors just like cross-drilled ones. I would go with the slotted rotors.
As for stopping tires will provide an increase in grip, but upgrading to better rotors will increase your stopping power as well.
Tsunami is offline   Reply With Quote
Old 08-04-2004, 10:26 AM   #5
jboss
Actually, stopping distance is what we are really worried about not braking power ( you called this stopping power which confuses the issue).
Bigger brakes, slotted brakes, drilled brakes etc WILL NOT reduce stopping distances unless your stock braking system is incapable of locking the tires---unlikely on most modern vehicles.
While big brake kits, fancy rotors and pads may change the FEEL of your brakes, improve or ruin the ability to modulate the brakes etc etc... they can not improve stopping distances because the limiting factor is the grip of the tire and not the ability of the brake.
These "upgrades" are rarely necessary even for racing and track events unless the brakes are unable to keep up with the amount of heat produced by your braking---highly unlikely in a drift car where the sessions are short and speeds are relatively low.
IF you are having issues with brake fade the things to do first are always 1) use an appropriate pad for your heat range and 2) use an appropriate fluid for your heat range. IF you are still having problems with heat, add brake cooling ducts......and as a LAST RESORT install larger brakes.
Notice that I never mentioned using slotted or drilled rotors because they are simply a waste of money unless you want to look cool or save a few grams on unsprung mass. Both were designed to help with "out-gassing" when the brake pads get so hot that they vaporize on the surface forcing the pad to float on a cushion of gas instead of touching the rotor----this is exteremely rare with modern performance race pads as they must be extremely hot (hotter than your brakes will get without boiling even the best fluid first) to do this.
So.....how do you know what you need to do for brakes???
First, have you ever had a brake fade or failure at an event?
If not, you probably need to do nothing.
If so, first check to make sure your STOCK system is in good shape and use a fluid and pad that are in the appropriate heat range.....
If you still have problems.....
1) You have to push the brakes harder and harder during a session in order for them to work---pedal may feel hard.
---Either your pad is outgassing as explained above, or your vacum operated brake booster is running out of vacum because you are at or near full throttle a lot.
---solution---replace pad with higher temp range pad...disconnect the vacume line to the brake booster and deal with the harder pedal or add an additional vacum resevoir to the system.
2) Your brake pedal becomes mushy or you have to pump the brakes to make them work----this is caused by over heating and boiling the fluid in the calipers.
----solution replace fluid with NEW---CLEAN higher temp fluid..
Old 08-04-2004, 10:33 AM   #6
Emagdnim
400lbs Gorillia
Emagdnim's Avatar
I agree if you can lock the tires with the brakes then the only way to decrese stopping distance is more traction(grippier or wider tires) and/or better balance between the front and rear brakes.
The only reason to go to a larger more powerful brake system is if your current brakes aren't enough for your current available traction.
Old 08-04-2004, 11:07 AM   #7
LucidStrife
drilling bad
I would definatly say that drilling your rotors would be a bad idea. If the weight of the rotors is such a big deal then I would focus on slotting it, getting a lighter material to have your rotor made out of, or maybe a smaller rotor is in order. Drilling hurts the rotor life by quite a bit, and hurts the cooling efficency of the vented rotors. I have heard that the life of a drilled rotor can be shortened by 80%, and the weight your losing is important, but not that important. I just cant afford to have my rotors changed out that often.
Lucidstrife
LucidStrife is offline   Reply With Quote
Old 08-11-2004, 07:57 PM   #8
Tuner
Oversteer
Another vote for slotted
Old 08-13-2004, 11:59 PM   #9
ma71supraturbo
ma71supraturbo's Avatar
Negative ghostrider. Tires have the most "grip" at around 10% slippage. You want a brake powerful enough to be able to HOLD the brakes just before lock-up for a long period of time. Hell anyone with a 1950's chevy can lock up all four tires at come to a sliding stop, but it certainly isnt the shortest or safest way to do so.
Bigger brakes increase the torque applied (larger rotor has more leverage than smaller) and also increase the surface area to help keep fade at bay.
Drilled and or slotted rotors increase the disc surface area and therefore help to transfer more heat to the atmosphere. However their effect is minimal in comparison to a bigger brake disc. Unfortunately bigger brakes require bigger wheels and the whole package weighs more -- so there is a certain point where you experience diminishing returns...
Modulation is helped mostly by having braided brake lines, quality fluid, and pads capable of withstanding the temperature range you anticipate. Additionally brake bias plays a large part as ideally you have all four tires starting to lock up at once (street cars almost always have the front tires lock up first to keep people from oversteering). The result is a slight loss in braking power.
Perhaps the most overlooked "brake" upgrade is installing stiffer springs. Soft factory springs will promote brake dive -- where the nose squats under hard braking. A lot of weight is transfered up front and the front brakes are overloaded with most of the work. Additionally the nose dive will cause suspension to add more negative camber so your tire's contact patch lessens (meaning your tire's have less overall grip)
Old 08-18-2004, 04:39 PM   #10
SaintDrift
Midengine drift?
SaintDrift's Avatar
Wow, I know when I'm performance driving, I always brake in a straightline. Limited nose dive is good, it keeps weight where you need it in a turn, towards the front. Once again, negative camber increases the contact patch in a turn. If you want to be fast, you trailbrake.
I don't know about you, but I've never had a car fade from the rotors overheating. Usually it's the brake fluid. So increasing pad to rotor surface area is good. Drilled, slotted, it's all bling. Go out and get you some good pad, steel brake lines, then some good brake fluid and call it a day.
SaintDrift is offline   Reply With Quote
Old 08-18-2004, 06:01 PM   #11
Ripper
post whore
Ripper's Avatar
or here
actually, it's all dependent variables for less stopping distances. depends on disc size, caliper size (surface area), and how much pressure is applied on the brakes.
personally i'd choose crossdrilled/slotted break rotors becuase they have the "sporty" look and it cools down the brake disc.
Old 08-18-2004, 08:35 PM   #12
hatebbobbarker
hatebbobbarker's Avatar
Send a message via ICQ to hatebbobbarker Send a message via AIM to hatebbobbarker Send a message via Yahoo to hatebbobbarker
has anyone seen rhys millens brake setup?
its wild.
hatebbobbarker is offline   Reply With Quote
Old 08-18-2004, 10:06 PM   #13
GRiDRaceTech
Dive is never good, it decreases rear grip and increases the propensity of the car to oversteer.
Negative camber CAN increase the contact patch in a turn, but only to a certain extent. A MacPherson strut will undergo positive camber change under load, yes, but only to a certain extent. Thus, too much negative camber and you have a decreased contact patch. I have a feeling you already knew this from your other posts (you sound very well versed in high-performance driving) but I just wanted to reiterate it to the newbies.
I agree that fade is usually brake fluid related or both brake fluid and pad related. I have good pads and great brake fluid and my brakes are awesome. I need to upgrade to stainless lines next for good feel.
Old 08-18-2004, 10:34 PM   #14
Craftsman
Craftsman's Avatar
Can I vote?
I vote for combination of sloted and drilled...
The reasoning behind my choice... Slots mainly are good for warming up the brake pads. They do an excellent job of warming them up. The drilled ones help in braking... So I like using both... Only problem is that the chances of wear occuring faster is only increased...
Matt.
Old 08-23-2004, 09:06 PM   #15
driftfreak
Pita didnt like my avitar
driftfreak's Avatar
before you vote...read this arcive of a discution on this very subject
http://corner-carvers.com/altimathread.php.html
very interesting read,,,but very long...
Old 08-25-2004, 12:34 PM   #16
GRiDRaceTech
... except that it turns out to be a moron arguing with the guy who is right.
Stick to what's in this thread. It's right and you don't have to deal with boneheads.
Old 08-26-2004, 09:54 AM   #17
zerodrifter
zerodrifter's Avatar
Send a message via AIM to zerodrifter
i have read the thread and i have a question. I here you guys taking about changing brake fluid helps the breaking. Can anyone explain how that works, and recomend soem fluids?
zerodrifter is offline   Reply With Quote
Old 08-26-2004, 12:32 PM   #18
GRiDRaceTech
Certain brake fluids have different wet and dry boiling points than others. Thus, they are harder to get overheated and cause brake fade.
I use Ate Superblue, but I've heard Typ200 is the same, just without the blue dye.
Old 08-26-2004, 01:29 PM   #19
ma71supraturbo
Motul 600 here. I have *heard* that you do not want to use this stuff on cars with ABS, but I've been using it for 10,000 miles with no problems
Old 08-27-2004, 07:31 AM   #20
malcolm
personally, we use Motul 600 in our 2800 lb Corvette, and we use OEM calipers, OEM-size rotors (slotted, with a better material than stock), and a racing pad. Works quite well.
Another fluid I would recommend: Ford 550. You might need to replace it more than other fluids, but it's DIRT CHEAP. It was recommended by Carroll Smith (brilliant engineer, who wrote many great books, such as "Engineer to Win" and "Tune to Win". Essential material in any racers' library). Apparently, the stuff was created by Ford for people who rested their feet on the brake pedal in their Lincolns.... and voila! One of the best brake fluids around was created.
As for drilled/slotted, my brake sponsor, KVR Performance, told me that slotted rotors give a little bit more bite, because it constantly takes off super-thin layers of pad material, giving increased friction when a new layer of material is exposed. Also, modern pads do expel gas, but just not nearly as much as older pads. As for slotted rotors, the slots would account for a loss of no more than 1 to 1.5% of the total surface area. Not really much to be worried about, especially considering the advantages.
Oh, and I would suggest **AVOIDING** dot-5 fluid.... I have never heard anything good about it.
Old 08-27-2004, 08:23 PM   #21
driftfreak
driftfreak's Avatar
All slotted rotors do is eat up pads faster..
and give a nice place for stress cracks to start. Crossdrilled ro dimpled are worse.
Ill just stick to sold rotors and good pads.
There cheeper, they wont stress crack like slottid or cross drilled rotors and have worked just fine for me, even at tracks like Nurburg ring and normal driving on the Autobahn in my FC..
crossdrilled/slotted are good for the race car bling..and will work fine on street cars.
Old 08-28-2004, 09:16 AM   #22
blargonator
Send a message via AIM to blargonator
what about brake pads such as ceramic pads or other types. i know ceramic pads take a long time to heat up for normal aplications so they are no good in actual street use. but what are the pros and cons of using metalic pads or ceramic pads?
blargonator is offline   Reply With Quote
Old 08-28-2004, 10:04 AM   #23
GRiDRaceTech
driftfreak... I don't know if you read the post by Malcolm, but the guy races Corvettes. He brings to the table A LOT of knowledge.
Ceramic pads have extreme resistance to heat, but should never be used on the street. They simply require far too much heat to be effective.
Metallic pads have decent resistance to heat and don't require much warmup. PBR MetalMasters is a pad that comes to mind when "metallic" is mentioned. I've heard good things from casual drivers about them, but bad things from the hardcore drivers.
It seems like the best brakes to go with nowadays are kevlar/carbon-metallic with maybe a hint of ceramic. My Axxis Ultimates are Kevlar/ceramic/metallic and are excellent. Great bite when cold, but when warmed up they'll slow the Earth's rotation. They have a maximum temperature of 1022 deg F, so they're very resistant to heat. I recommend them highly. I've also heard great things about Hawk pads and I know the Cobalt Racing pads are great on racecars... I dunno about street applications. Just avoid EBC like the plague.
Old 09-07-2004, 08:21 PM   #24
driftfreak
driftfreak's Avatar
yes i did read the post,
and yes i have done my own bit if racing...
"Ceramic pads have extreme resistance to heat, but should never be used on the street. They simply require far too much heat to be effective."
Not true, a lot of OEM pads now days are ceramic..and used for daily duties in just about all forms of cars from sports to SUVs
"Metallic pads have decent resistance to heat and don't require much warmup. PBR MetalMasters is a pad that comes to mind when "metallic" is mentioned. I've heard good things from casual drivers about them, but bad things from the hardcore drivers."
All depends on the make up of the pad...Ive had some semi metallic and carbon metallic pads that are of such a high heat range that they are useless unless i drag the breaks for a warm up lap or so...not good for street use..
"It seems like the best brakes to go with nowadays are kevlar/carbon-metallic with maybe a hint of ceramic. My Axxis Ultimates are Kevlar/ceramic/metallic and are excellent. Great bite when cold, but when warmed up they'll slow the Earth's rotation. They have a maximum temperature of 1022 deg F, so they're very resistant to heat. I recommend them highly. I've also heard great things about Hawk pads and I know the Cobalt Racing pads are great on racecars... I dunno about street applications. Just avoid EBC like the plague."
It all depends I feel the best breaks are the ones that will stop you this quickest with least amout of heat build up time and time again....
BTW look at the pic below, thats a corvette rotor from a Lemans car at Spa-francor chaps track...can we say heat cracked?
if you need a larger version of the pic let me know...
BTW what class is his vette in?
Old 09-07-2004, 10:13 PM   #25
f8ldzz
Wow, do you have proof of such claims?
Ceramics really have nothing to contribute to friction coefficient, but they do have good heat rejection properties.
Most ceramics are abrasive, so significant amounts of ceramics in brake pads would make for a very abrasive brake pad that should eat brake rotors.
I doubt OEM's would bother with such "exotic" technologies.
OEM's would prefer great low temp performance while being brake rotor friendly.
Higher temp performance is sacrificed...unless you're Porsche or Ferrari.
It's been always a sacrifice between low temp use versus high temp use.
I've never seen a brake pad offer great "0F" performance versus it's performance "at temp" at 500F or higher.
Thus, if you're running "track brake pads", I'm assuming some trade off in terms of low temp performance.
I've been on Porterfield R4S and Hawk HPS and HP+, and they all suffer from low temp performance.
That first stop after you drive the car sitting overnight might be a little vague, but stopping after that should not be a problem.
Most "race" brake pads will offer okay low temp performance, but it should eat brake rotors in a jiffy - i.e. Hawk Blue.
Most "semi-metallics" are like this.
Tags
drilled brakes, slotted brakes, slotted or drilled, slotted or drilled brakes
