This is a discussion on SR20DET Recommendations? within the TECH Discussion Forum forums, part of the TECH Discussion category; I'm seriously about buying an SR20DET. I'm almost done saving up for a S13... My friends are telling me different ...
Recommendations on SR20DET
My friends are telling me different things for the SRs... My buddy is telling me to get the S15 SR20VET. My friends who own a car shop are telling me to get the red top... For me, I plan on getting the motor installed and that's it.. No more modifications to it... If anything, it's just going to be intake, exhaust and other small tweaks. I'm not looking for maximum horsepower here. I'm looking for high tech engine and reliability... I'm going to Japan this winter so finding one or buying one won't be too difficult. I love Tokoyo Auto Salon ![]() Matt. |
The s13 black top or red are good choices, red's will be cheaper just because they're generally older with more mileage but essentially the same. If you plan on keeping the motor a while, you may want to do the timing chain job while the motor's out. It'll be alot easier that way and they use the usdm sr20de timing chain kit for the 91 sentra se-r if you're interested.
Red or black top, the sr20 motors are all nice and will provide good hp...205hp/200ft lbs. I would go with a redtop just because of the price difference. The mileage would still be low. It is usually about 35-45k miles. For a drift car, that would definately be a good amount of power!
what are the different specs for redtop and blacktop
noob
1991-1993 S13 Silvia and 180sx - redtop
202hp@6000rpms 203lb-ft@4000rpms stock turbo Garret T25, 0.64 a/r Exhaust, 0.80 a/r compressor high port head, 370cc/min injectors 1994-1998 S14 silvia- black valve cover with a hump that peaks at cylinder #3 217hp@6000rpms 203lb-ft@4800rpms stock turbo Garret T28, ball bearing 0.64 a/r exhaust, 0.60 a/r T04B compressor low port head, VTC variable intake, cam timing 370cc/min injectors I also have the specs on the 1994-1998 S13 180sx blacktop and the 1999-2001 S15 silvia blacktop Last edited by LexmarkX73; 08-05-2004 at 02:41 PM. |
