This is a discussion on S14 K's Brakes within the TECH Discussion Forum forums, part of the TECH Discussion category; I own and Actual Silvia K's S14 in Japan and have been trying for nearly a month to find brake ...
I own and Actual Silvia K's S14 in Japan and have been trying for nearly a month to find brake information. I am looking for Brake Rotors (drilled,slotted,both) for the front and rear and Hawk HP+ Pads front and rear. Everyone in the states does the conversions for this and that. I have stock 4 piston front calipers and one piston rears. I have some ideas as to what might work but since I will have to mail them to Japan I don't want to be guessing. I pulled the pads and rotors, took measurements and made outlines of the pads.
Is there anyone out there that knows for sure what part numbers I need? Has anyone done this yet? Is there a brake specialist, Company, willing to work with me to find out for sure? I appreciate any help. Thanks . |
Sixgun
This is a great question, I will see if I can find any info for you. In the meantime, bump it every couple hours or so until some of the more knowledgable people get on. I would like to know the answer myself.
the front are the same as the Iron 30mm Z32 Brakes...
how do I know know this because my front brakes are off a JDM S14 K's... back for the back brakes it is my understanding that it is the same as the USDM sliding single piston brakes... |
Here are some measurements I took...
Front: Rotor Diameter = 280mm* Rotor Thickness = 30mm* Hat Outside Diameter = 155mm* Pads are Sumitomo SN258P E7X13 Rear: Rotor Diameter = 258mm* Rotor Thickness = 9mm* Hat Outside Diameter = 165mm* Pads are Sumitomo SN551P 8G02 **** I forgot to measure hat hight. Time to pull the breaks... AGAIN. * All measurements are made with a tape measure so may be off a little bit. NIS14 - Call me the anal retarded aszmunch... but can you give me a year for the Z32 30mm.... Just so I can place my order? Thanks.... |
