What Coilover System Would You Use? (POLL)
Poll: What Coilover System Would You Use?
Poll Options
This is a discussion on What Coilover System Would You Use? (POLL) within the TECH Discussion Forum forums, part of the TECH Discussion category; What Coilover System Would You Use?...
Old 08-09-2004, 07:41 PM   #1
PhoPower
Miata Touge Special!
PhoPower's Avatar
Send a message via AIM to PhoPower
PhoPower is offline   Reply With Quote
Old 08-09-2004, 08:32 PM   #2
PhoPower
PhoPower's Avatar
O and also why you would use the brand and what model...
Old 08-09-2004, 09:15 PM   #3
ma71supraturbo
ma71supraturbo's Avatar
Price no object? Custom made Ohlins
Price only a small consideration? Jic Flt-A2's, Tein RE's
Price a substantial consideration? Silkroad
Things to look for:
Ability to change ride height independently of spring preload (needed for propper corner-weighting)
Aluminum bodies (lighter units for less unsprung weight)
Ability to adjust rebound/compression damping individually (usually only available in race-spec and custom-made coilovers)
Ability to swap spring rates easily (common spring length and diameter)
Nitrogen gas (more consistant damping in wide temperature ranges)
Inclusion of Upper pillow-ball mounts
Old 08-10-2004, 12:23 AM   #4
chmercer
out of that list, apex. money no object, cashiew i would like to try out. or daiyama.
any at least half decent coilover should have dual height adjust, heim joint mounts, camber plates, inverted front shock, monopiston. spring interchangability dosent matter because if you want to change spring rates you will have to send them in to get revalved anyway.
chmercer is offline   Reply With Quote
Old 08-10-2004, 09:16 AM   #5
ovenmittjustice
ovenmittjustice's Avatar
I always thought aragostas looked nice... but only if i never had to drive my car on the street...
ovenmittjustice is offline   Reply With Quote
Old 08-10-2004, 10:38 AM   #6
GRiDRaceTech
GRiDRaceTech's Avatar
KTS/SPL, mostly because my order for them is pending.
Old 08-10-2004, 05:00 PM   #7
penpen989
Send a message via AIM to penpen989
i own tein type flex coilovers for my miata. I am super happy with them! They can be soft as stock or set for drift or set for autox, and i do it all with the touch of a button. The edfc unit has these motors on each of the shocks and u just set the damping force from the control unit inside the car and can save it to a preset. u have three presets, its awesome, i never have to get out of the car to change my settings. i also have a set of unopened HKS Hipermax II dampers for a miata but im so happy with the performance of the teins that i might just sell them at a loss.
penpen989 is offline   Reply With Quote
Old 08-10-2004, 10:27 PM   #8
PhoPower
PhoPower's Avatar
Im thinking on what coilovers to get and was looking at the cusco comps i was wondering if anyone on the board has them if they can give me some feedback on them.
Old 08-10-2004, 11:29 PM   #9
Craftsman
Craftsman's Avatar
I'd stick with Tein since they're been doing it for years in Japan...
Matt.
Old 08-10-2004, 11:44 PM   #10
ma71supraturbo
TEIN doesn't have dual height adjust in most of their models, neither does HKS nor the lower lines of Cusco and JIC.
Tein and Cusco's lower models of coilovers do not come with a solid upper pillow-ball mount -- you have to order it separately.
As for spring interchangablity -- you can use the same damper and use a small range of spring rates (assuming you have adjustable dampers). Hell many of the US-spec coilovers are just the japanese spec with lower spring rates *cough* JIC *cough*
Anyway, here is a chart I made of readily available coilovers (and their features) for the MK3 supra:
Old 08-11-2004, 12:05 AM   #11
allblackS14
i use Tein Circuit master with EDFC and it works excellent. got em slightly used for 550 bucks
allblackS14 is offline   Reply With Quote
Old 08-11-2004, 05:31 AM   #12
turbo23
Send a message via AIM to turbo23
Silk Freakin Roads
turbo23 is offline   Reply With Quote
Old 08-11-2004, 02:49 PM   #13
PhoPower
PhoPower's Avatar
Anyone else have some input on what coilover system to use or what you use?
Old 08-12-2004, 04:55 PM   #14
penpen989
you know, if your on a budget theres no sense in breaking the bank to buy something like a zeal setup or type HE's. The tein basic damper is around 750 bucks and it may not be the stiffest damper, around 7kg front 7kg rear for the s13, but it is a great set up for the money and will help you out alot. or if you have less money than that, the KYB AGX shock set hardest in front and 2-3 clicks from hardest in the back along with the RS*R race springs are just as nice! If your going to go with a shock spring combo, the RS*R heavy duty race springs are really stiff and are actually the only lowering spring made with drifting in mind. Just something to think about.
Old 08-13-2004, 01:25 AM   #15
180fan
JIC's just aren't what they used to be. Alot of the newer made coils are having issues blowing from what I've seen on various boards and locally.
Teins are awesome bang for the buck and can be rebuilt stateside.
Zeals take it for me though, you said best coil overs out there, and no ones got a better rep than Zeals for coilovers. Top it off with their rebuilding stateside, makes them all the better. 3 days turn around average.
Just some notes I've realized along the way. Alot of other people think too much about adjustability. You don't need a million levels of dampening for your coilovers, once you've found your set, most people generally keep it at that. If they're well built, honestly you don't need that much adjustability with the dampening. Another thing is that with the more settings you can set, the more difficult it becomes to tune them and the greater risk of you putting a bad setting and possibly damaging something. All you should be looking for is something to get the job done. Not something that'll leave you hunting for settings for a month and a half or risk your neck trying those different settings.
Old 08-13-2004, 02:40 PM   #16
chmercer
[/img]
tein has dual height adjust in any of their models that arent total crap. re rs he flex (although this is crap soft springs it does have dual height and heim joints)ht hg n1.
cuscos lower models dont have that stuff because they are for "Street" use or some trash. more like wuss use. and i think everybody knows JIC sucks by now.
Old 08-13-2004, 05:16 PM   #17
penpen989
you talk alot of trash there bud, what system do you use? and dont come up with some bs answer either. And anyone who says the flex is too soft must be driving a race only car. The flex on an S13 is even harder than the HE. (flex is 7kg/7kg HE is 7kg/6kg)
Old 08-13-2004, 11:09 PM   #18
chmercer
HEs are 8/6 kgmm on both s13 and s14. Flex on an s13 is 5/4, 6/5 on an s14. you did get it right for na8c though, 7/6. get your numbers straight before you try to start shi.t. i run kts sp beta with 8/6 not that it has anything to do with flex being soft. tein agrees with me. taken from www.tein.com
TEIN Type FLEX damper kit was designed to provide driving comfort and sports performance with its full-length adjustment system. We have incorporated separate height and preload adjustments, which allows you to have various set-ups to meet different road conditions. The FLEX Damper kit includes pillow ball upper mounts and is compatible with the EDFC, for maximum performance for the streets.
Old 08-13-2004, 11:19 PM   #19
emission
Moderator
emission's Avatar
silk road... Can't belive there voted most popular along with teins.
Old 08-18-2004, 02:36 PM   #20
URMachines
URMachines's Avatar
is it me or are all those spring rates out of wak??
even if thats a japamese chart, they seem oddly combined
URMachines is offline   Reply With Quote
