CA18DET or SR20DET?
This is a discussion on CA18DET or SR20DET? within the TECH Discussion Forum forums, part of the TECH Discussion category; I dont know if this has been discussed but which would you recommend for your drifter(s13)? For originality i would ...
Thread Tools Rating: Thread Rating: 150 votes, 5.00 average. Display Modes
Old 12-03-2003, 02:51 AM   #1
s13/350z
s13/350z's Avatar
CA18DET or SR20DET?
I dont know if this has been discussed but which would you recommend for your drifter(s13)? For originality i would say ca18 only a little smaller and a little less HP. but with the money you save on the cheaper motor u could make more power than the sr20 stock. I guess u can understand what i just meant. anyways thanx for any input in advance.
Old 12-03-2003, 03:02 AM   #2
QuickStyle
i can almost garanty that every one will tell you to get the sr20 but i know plenty of exelent drifters over here that run the ca18 with no complaints. i used to have a ca18det in my silvia and it was a great engine i only took it out because i decided to go N/A with that car. if you wanna save a few bucks go with the ca, its a strong motor that can hold alot of boost.
QuickStyle is offline   Reply With Quote
Old 12-03-2003, 03:50 AM   #3
s13/350z
s13/350z's Avatar
do you know what the CA red lines at? and is the swap and harder easier than the sr?into an s13 240sx
Old 12-03-2003, 04:01 AM   #4
QuickStyle
ca red lines at 7500 but i've taking them to 8500 with no problem.
the swap would be the same as an sr.
Old 12-03-2003, 04:34 AM   #5
Feint
ƒhƒŠƒtƒg
If you were to get a CA18DET,get rid of the stock turbo ,it's a joke.
Old 12-03-2003, 05:08 AM   #6
s13/350z
s13/350z's Avatar
upgrade turbo= FOR SHURE
Old 12-04-2003, 02:21 AM   #7
Nightwalker
CA18DET= hard to find parts.
Old 12-04-2003, 05:06 AM   #8
panda_3ight_6
Senior Member
panda_3ight_6's Avatar
CA18= OLD
SR20= Not so old...
but not too many people here put CA18's in there S13's...
Old 12-05-2003, 11:56 PM   #9
TokyoDrifterxo7
Tokyo7even
TokyoDrifterxo7's Avatar
id just go with a SR
Old 12-06-2003, 07:53 AM   #10
aphxero
You can get CA parts from nissan here. Much like the SR an n/a version came out in the states. It came in the pulsar nx. Parts wouldn't be any harder than getting sentra parts for the SR.
There's nothing wrong with old motors. You've just gotta keep a closer eye on them and give more tlc. Having an old motor has made me closer to my car if that makes sense.
Old 12-07-2003, 08:06 PM   #11
TFIRDS13
u can get ca parts at autozone or anyother store. like he said a na version came out in the states. all parts for the ca are the same as na and det just. just the injectors are bigger in det the throttle body is bigger in na. i think the cams are a little bigger but dont quote me on it.
TFIRDS13 is offline   Reply With Quote
Old 12-07-2003, 08:21 PM   #12
jdmdrewS14
Full Moon
jdmdrewS14's Avatar
Send a message via AIM to jdmdrewS14
Thats easy SR20. Dont get me wrong but I like the CA but the SR has so much more potental. But do what you want not what others say is better at least youd be different
jdmdrewS14 is offline   Reply With Quote
Old 12-07-2003, 08:21 PM   #13
prodigy
Broken 240sx
prodigy's Avatar
Send a message via AIM to prodigy
I am going CA18DET because I want to be different and I see no problem with having an engine that is a few years older then the SR red top. What car in the states did the CA18DE come in? I think I should know this seeing how I am going to be a CA owner. The years it came in would also be greatly appreciated.
prodigy is offline   Reply With Quote
Old 12-11-2003, 10:39 AM   #14
D1 DRIFTER
D1 DRIFTER's Avatar
sr20det all the way!
the sr20det has a huge power potential.. i know of ppl who have a 400rwhp sr20det on stock internals(ernie fixmer) and still relaible with nothing liek pistons or rods etc.. thats what i think and u aare safer with gonig sr cuz of the newer they motor the more info u can get on how it was used...
just my 2psi.
Old 12-11-2003, 11:02 AM   #15
BeerBringer
The CA18DET internals can handle a bit over 300 hp. The stock turbo (Garret T25) can handle a maximum 270 hp on a CA18DET if the engine is tuned the way i should...
300 hp in an S13 is ALOT of power!
BeerBringer is offline   Reply With Quote
Old 07-12-2004, 11:45 PM   #16
ca18det_s13
i have no problem with the ca18det... i have quite a few ca18det motor i'm currently on my second car with an ca18det...
fyi... not all of the parts from the american spec pulsar nx will fit on the jdm or uk ca18det.. for example the alternator doesn't fit the mounts are different i ordered one from autozone for my silvia and it never fit it was opposite probably cause it was mounted on the other side or something... i'm running 660cc injector with an sds system and a couple of other things... its should be pretty fast i haven't ran it yet cause i still need to wire it up, but my silvia with a ca18det kept up with a srt-4 wit mods on 7 psi of boost the ca18det can hold its own .... it has a cast iron block and one lobe for every valve unlike the sr20 alumin block with one lobe for every two valve ... ca18det does have pretty okie aftermarket backup not as much as the sr20 but enough www.takakaira.com they have the most ca18det parts i have seen... i hope this help whoever is deciding on sr20 or ca18 if you need any hard to find parts i have lots of spare parts just email me and i see if i can help you out....
ca18det_s13 is offline   Reply With Quote
Old 07-14-2004, 10:34 AM   #17
svtxchinoy
I'm RICH B*ATCHH!!
svtxchinoy's Avatar
Send a message via AIM to svtxchinoy
Stick with the CA til it gives up. Thats the time to upgrade to the SR.
svtxchinoy is offline   Reply With Quote
Old 07-14-2004, 12:11 PM   #18
Thai Juku
Thai Juku's Avatar
Sorry to be unorthodox...But I prefer the SR20VE...It's all about total balance for me...
Thai Juku is offline   Reply With Quote
Old 07-14-2004, 09:48 PM   #19
TeamSLIPdrifter
Nice rx7, is it 4 or 6cyl
TeamSLIPdrifter's Avatar
Send a message via AIM to TeamSLIPdrifter
Like all the veteran drifters on here (not me), drifting is all car control, not power. Id go with one that provides the better balance. I think CA18 is lighter but im not sure. And if it is lighter it still provides you with enough power. Im sure youll be fine with the CA18
TeamSLIPdrifter is offline   Reply With Quote
Old 04-08-2008, 06:40 AM   #20
jeffwins24
Send a message via AIM to jeffwins24 Send a message via Yahoo to jeffwins24
Go to a nissan dealership and ask about importing parts from other countrys
they'll look for a number and hand you it, call that number up and you can talk with someone from nissan about buying the part you need and importing it.
and if your lazy theres also craigslist and ebay.
not to mention the CA18DET is lighter and stronger then the SR20DET.
jeffwins24 is offline   Reply With Quote
Old 04-08-2008, 07:09 AM   #21
JonnySlick
JonnySlick's Avatar
Location: Just Moved to Crossville, TN from Las Vegas ... wow what a change!
Send a message via Yahoo to JonnySlick
^ you're an idiot...CA18DET part are like ALL here in the states!
go for the CA!
JonnySlick is offline   Reply With Quote
Old 04-08-2008, 08:45 AM   #22
Piner
Piner's Avatar
the parts that dont fit the from the pulsar can be ordered from the 1985 200sx turbo that had a CA18ET SOHC but all the RWD stuff is the same
Old 03-24-2009, 08:38 AM   #23
Cold Sun
180sx
the 180sx is the name for the hatchback that carried the ca18det in Japan. the 240sx hatchback in the states is the same thing but with a different motor.
Old 03-28-2009, 11:45 PM   #24
nemesis91101
Send a message via MSN to nemesis91101
Cast my vote for a s13 blacktop. Only reason to go redtop is to instantly do a rebuild if u plan on runnin with oem internal for 5 or more years go blacktop. Plus more torque than a ca. I luv it it just pulls all the way to redline unlike the ka. s13 silvias I read do 0-60 with that motor in 6.18 with 3.6 final drive where 240s here come with a 4.083 add front mount instead of a side mount u got urself a fast lil car or cud be in 6.5 still fast anyway. As more me I decided to be different by driving a 240 in my town there's only less than 10 unlike stangs n all that. I can afford to have bad seals n gaskets goin to school so that's why I wanna blacktop not an old ca I just wanna drop it in n have a runnin car.
nemesis91101 is offline   Reply With Quote
Old 03-28-2009, 11:49 PM   #25
nemesis91101
Just looking at it from a cash stand point plus on the sr u mess up ur cylinder walls bad get new sleeves wala
Tags
ca18det or sr20det, ca18det vs sr20det
