Bushings
This is a discussion on Bushings within the TECH Discussion Forum forums, part of the TECH Discussion category; Bushings are usually located where all your suspension bits connect to the chassis. They are there to dampen vibration and ...
Old 08-14-2004, 07:18 AM   #1
Ralli///Art GS
Battle Ready.
Ralli///Art GS's Avatar
Send a message via AIM to Ralli///Art GS
Bushings
Bushings are usually located where all your suspension bits connect to the chassis. They are there to dampen vibration and reduce shock. In road cars they usually consist of rubber "tubes" with a steel insert that a bolt will pass through. I don't know how to really describe them, just look where your suspension components meet your chassis and you'll see the rubber. The problem with the factory bushings is that they are soft and compliant, this provieds a better and quieter ride. They are detrimental to handling because they flex under load, causing the suspension geometry to change while cornering. This change can lead to unpredicatble and sloppy handling. When upgrading you would go to a polyurethane bushing. A full kit will cost around 120.00 or so depending on what car you have. They are an absolute nightmare to put in, but well worth the effort. The ride is much harsher however the handling gain is fantastic. Look to company's such as Prothane or Energy Suspension for bushing kits.
Ralli///Art GS is offline   Reply With Quote
Old 08-14-2004, 07:19 AM   #2
Ralli///Art GS
Battle Ready.
Talking
Ooops, that was in response to someones post, but ended up being a new thread....
Old 08-14-2004, 10:35 AM   #3
chmercer
dont waste time with polyeurethane. get aluminum bushings if you really want to go cheap, but what you really want is to replace them all with heim joints.
chmercer is offline   Reply With Quote
Old 08-14-2004, 11:21 AM   #4
Craftsman
Craftsman's Avatar
You can describe bushings using your joints on your bones as an analogy. The cartiliedge between your bones acts as a buffer.
When you have soft bushings, you're going to have a soft ride but not be able to take a hard beating without severe damage... I've worn out the factory bushings on all the cars I have owned thus far.
With polyurethane bushings, they're stiff enough to take a beating, but yet still dampen the ride considerablely.
I honestly don't recommend the aluminum bushings if this is going to be a street application as you're going to damage your suspension parts and frame in the long run due to undamped vibrations (Resonance)...
(Someone hurry up and hire me... Please.. I need a job working on this stuff. I'll relocate to anywhere...I studdied Mechanical Enginering...)
Matt
Old 08-14-2004, 01:46 PM   #5
Wayne
Wayne's Avatar
ill higher you you can be my fd mechanic i could pay you umm, stuff and possibly even money eventually, but ya u had it right on the money, great analogy
Old 08-14-2004, 06:50 PM   #6
Craftsman
Craftsman's Avatar
Hehehe... Nissan... Do you hear me? I know my stuff I can build parts for racing...
Matt.
Old 08-14-2004, 08:01 PM   #7
Wayne
Wayne's Avatar
hrm lol well if i get a nissan would u work for free ahahhaa
Old 08-15-2004, 02:08 AM   #8
Craftsman
Craftsman's Avatar
hehehe... I meant the factory...
Let's put it this way, I'm not a greese monkey. I know $*$^ about actually fixing a car. I didn't get a chance to do the wrench time. I do more now as of late and I enjoy it, but I'm an engineer. I'd be designing the parts.
Matt.
Old 08-15-2004, 04:15 AM   #9
AlexPfeiffer
Driver
AlexPfeiffer's Avatar
Who the hell is stupid enough to use aluminum, that is just wrong. If you use anything other than a rubber or a bearing (rod end or heim joint), then it would be Delrin.
Old 08-15-2004, 04:56 AM   #10
godigy
Highway Drifter
Send a message via AIM to godigy
Hey that was my topic your suppose to put your post, lol. http://www.drifting.com/forums/showt...light=bushings Its cool man but hey thanks for your immediate response to this topic enjoy!
godigy is offline   Reply With Quote
Old 08-15-2004, 10:47 AM   #11
Craftsman
Craftsman's Avatar
People who don't know about suspensions and the flex they require to stay as suspensions would use aluminum... A suspension is called a suspension for this reason. It suspends the car from the road... It requires some form of flexibility to adjust camber and toe to maintain traction to the road... I recommend Battle Version Suspension parts for this reason. Battle Version parts are superior to stock parts.
Matt.
Old 08-15-2004, 11:40 AM   #12
chmercer
ive ridden in cars with poly bushings, couldnt feel it at all. heim joints are an improvment though. stiffens things up nice.
about who would be stupid enough to use aluminum bushings, *shrug* ive seen them for sale, never ran them myself. bushings are just too much work for somthing that you would have to replace later when you run out of adjustment. (imho)
