This is a discussion on mazda LSD what do you recomend within the TECH Discussion Forum forums, part of the TECH Discussion category; I bought fc3 for $500 and it has some balls any way, drivers of an rx7 what kind of lsd ...
I bought fc3 for $500 and it has some balls any way, drivers of an rx7 what kind of lsd would you recomend for the low $
thanks |
Pita didnt like my avitar
if its NA then a S4 rear out of a GXL is the best bang for the buck
Boro Miata
Torsen LSD's roxors all mazda drivers SOxors
Sounds like an NA.
NA's have very little aftermarket LSD options. Good luck. |
Rollin' on 14's
What about for Miatas? 1.6 specifically. I've heard of FC diffs being used in them. What I'm asking is is there any cheaper alternative for a clutch type diff than a $800 KAAZ LSD?
Miata Touge Special!
What about miatas with the 1.8? Kaaz, Cusco, Tomei?
#7 | |
Now Rockin Roadster #2!
www.corksport.com
Mazda speed $649 should have one for the FC since there the same... http://www.corksport.com/main.php3?p...3Fcat%3D227137 any roadster questions PM me any time i can track down anything. |
learn to drive car first before you put lsd, its kinda like taking out the abs out so you dont have to rely on it. itll help you out more in the future.
I prefer the Torsen or gear-type LSD for the beginner drifter.
This types of LSD has very little maintenance, as opposed to the clutch-type LSD. The clutch-type LSD needs to be rebuild depending on use and abuse. The downside is that it cannot handle as much (torque) load as clutch-type LSD's. In grip driving, the Torsen is the preferred type of LSD. Why? The Torsen has the most linear rate of lock-up. The more it slips, the more it tries to lock-up. This is good for beginning drifters, as it locks up the left and right wheels but in a progressive manner. Clutch-type LSD's has basically two stages in locking up. Prior to the clutch packs engaging, both wheels spin easily of each other. Once you hit the lock-up point, it aggressively locks up. If you're familiar with it's lock-up point, this is not a problem. It can be unnerving for beginners trying to learn. |
