turbo efficiency
This is a discussion on turbo efficiency within the TECH Discussion Forum forums, part of the TECH Discussion category; I looked for this topic and it came up with a bunch of way off topics for this and i ...
Old 08-28-2004, 08:41 PM   #1
bboyt3nsk
Dinosuars=Jesus Horses
turbo efficiency
I looked for this topic and it came up with a bunch of way off topics for this and i searched through about the first 25 and i couldnt find this question...Is the stock turbo on a SR20 (91-93) a T25 or T28? and whichever one it is how much boost until it is past its efficincy range? and if i did get a wastegate would that help the effeciency range at all or just allow more boost?
God bless your soul if you can respond to all these question...bles you if you even respond at all!
thanks alot
Old 08-28-2004, 09:09 PM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
It's a T25.
How much boost? I'd guess between 15 and 18psi.
Wastegate would not help. If you wanna run lots of boost, you'll have to increase the size of the turbo.
Old 08-28-2004, 09:11 PM   #3
bboyt3nsk
When would a upgraded wastegate help?
Old 08-28-2004, 11:56 PM   #4
180fan
The stock t25, I wouldn't run past 17psi. The wastegate will not increase efficiency. A wastegate only opens at a specific amount of boost and lets it stabilize at that boost number. All an aftermarket wastegate will allow you to do is keep your turbo from spooling more than it's supposed to. The stock wastegate does leak. I forget the number though. I'll try to dig it up later.
Old 08-29-2004, 07:09 PM   #5
f8ldzz
The wastegate's sole purpose is to control boost levels by the turbocharger.
An "upgrade" wastegate implies larger wastegate.
A better wastegate controls boost better.
Inferior wastegates cause boost creep - this is due to the turbocharger overrunning the (too small) wastegate, which causes overboost and boost creep.
Boost creep can kill engines due to the uncontrolled nature of the boost levels.
Old 08-30-2004, 09:09 AM   #6
bboyt3nsk
Goodstuff I love this forum
Old 08-30-2004, 09:35 AM   #7
240LoVeR
240LoVeR's Avatar
Send a message via AIM to 240LoVeR
what about a BOV? when would it help if at all?
240LoVeR is offline   Reply With Quote
Old 08-30-2004, 10:03 AM   #8
Parry
Parry's Avatar
No.
A BOV vents air pressure from the intake tract to keep from stalling the turbo when you close the throttle.
Old 08-30-2004, 03:55 PM   #9
f8ldzz
The sole responsibility of the BOV is to prevent "compressor surge".
What is compressor surge?
This is when airflow tries to "backpeddle" over the compressor wheel section.
Normally, the turbo sucks in air and then spits it out into the intercooler / engine.
If there is a spike in pressure after the turbo, the airflow suddenly stops and sometimes actually travels backwards!
If this happens, it's called compressor surge.
You can sometimes hear this as a "fluttering" sound.
Compressor surge is BAD.
You basically try to make a 50,000RPM to 150,000RPM turbo (compressor) wheel stall to a dead stop or even spin in reverse.
In mild circumstances, this puts tremendous load on the thrust bearing on the turbo.
In extreme circumstances, it will tear the compressor wheel off of the shaft.
So why this dangerous situation?
When boosting hard, everytime to lift of the throttle (i.e. to shift on a manual transmission), the throttle plates on the throttle body snaps shut.
The turbo cannot stop on a dime, so it's still trying to pump air into the engine.
But the throttle body slammed shut?
What happens?
There is a huge pressure spike in the entire system between the turbo and the throttle body.
This is where the BOV comes in.
By triggering the BOV, positioned between the turbo and the throttle bodyt, to act like a relief valve in between the throttle body and the turbo, this sudden pressure spike is relieved.
This is why you hear the loud WHOOSH; it is this pressure spike being relieved.
So the BOV is not just there to make "cool noises".
It's there to prevent damage to the turbo from compressor surge.
Old 09-01-2004, 12:17 PM   #10
LOVMUFN
Drift Assoc. - Lead Tech
LOVMUFN's Avatar
Sport Compact Car did a BADA$$ article in one of their issues about turbo effeciency. If I can find it in my collection I will post the issue number and if it is legal I might post it on my web site (giving proper credit where due) and link it here.
Old 09-01-2004, 12:46 PM   #11
malcolm
when we first started running an 87 turbo FC3S, we had only one BOV, and the turbo lasted about 10 laps (mind you, it was the original turbo, so road racing the thing was probably the last straw for it).
We put on two stock BOV's, and the turbo lasted about a year running on 14 psi (that's about the best you can hope for with the cheap Hitachi turbo... the turbo was from the same manufacturer as my microwave!). For a turbo FC3S (I know this is a little off-topic), I would suggest either two stock BOV's, or one, big, quality, aftermarket BOV. With that, you'll get approximately the following turbo life:
7 psi - probably 5 years
10 psi - about 2 years
14 psi - about a year
17 psi - every three or four races (a "race weekend" is about 2 hours of track time)
Once you go above 12 psi, you'll need either big injectors, or plumb in a third injector upstream of the intake that comes on for any boost over 12 psi.
Yeah, this is a little off topic, but I included this just from what I learned from my car, and the cars of a few of my friends. Moral of the story: BIG blow-off valves are essential. (and they sound cool too!)
Old 09-01-2004, 01:41 PM   #12
240LoVeR
240LoVeR's Avatar
thanks guys, keep this thread going its really informative!!
Old 09-01-2004, 03:50 PM   #13
kaosman
Yeah the stock Hitachi turbo sucks, but for what it was designed to do, its decent. 14 psi is a LOT of boost for that turbo and even with a great BOV its gonna die a glorious death after not too long.
12 psi with an AIC & injector isn't a good idea...due to the nature of the FC's engine management you'd need to run a FCD to get boost above 8.6. So basically at 12 psi you're running timing maps set at 8.6 psi. This leads to a dead engine. For the FC, you really need a standalone to push more boost than 11-12 psi reliably.
kaosman is offline   Reply With Quote
Old 09-02-2004, 03:26 PM   #14
malcolm
perhaps, but with our car, we ran 14 reliably, and just had to change that cheap turbo once a year. Also, a friend of mine was running 17 psi, and he got about four races out of his before he would rebuild/replace them. He was the guy running a third injector, before the manifold. I am not sure how he configured or operated it, but it worked well for him. Next time I see him, I'll ask him how he did it, and post on here.
Old 09-03-2004, 09:01 AM   #15
kaosman
Oh no I don't doubt it, wasn't stating that it was impossible. Just a bad idea, thats all. With the additional injector you could get it pig rich and compensate for the lack of timing *Censored**Censored**Censored**Censored**Censored**Censored* at those boost levels and the car will run decent. But with an EMS, you can get the timing right and drop fuel down a little bit for more power.
Old 09-05-2004, 09:04 PM   #16
malcolm
yeah, I'm not sure how well it worked.... however, it was a cheap way to do it.
Old 09-05-2004, 10:00 PM   #17
Norcalidrifter
Registered Alcohol user
Norcalidrifter's Avatar
Send a message via AIM to Norcalidrifter
t25 is a small turbo. Usually car companies would put similar turbo as the t25 in their cars.
Norcalidrifter is offline   Reply With Quote
Old 09-07-2004, 09:41 PM   #18
LOVMUFN
LOVMUFN's Avatar
Stock turbo on my sr is at, like, 1 BAR when I went above that the turbo felt strained and exhaust gas temp. climbed too fast for my taste. With a SARD FPR my car runs GREAT at 1 BAR, I use it everyday and I have had it for almost 2 years. Z32 sidemount too. I also change my oil very often, clean piping and don't let the crank case vent go into the intake, I don't like the oil mist going in there. With the little turbo don't get a huge exhaust, keep it small, I still use stock dohc ka exhaust and my car runs wonderful, you can't hear it, but it runs great.
still looking for the article.
Old 09-09-2004, 06:26 PM   #19
bboyt3nsk
Where do you get SARD products from?! I have a sard hose on my apexi BOV and it came with it on...but i wanna know how the mercedez mechanic gets his stuff from!
Old 09-10-2004, 06:55 AM   #20
LOVMUFN
LOVMUFN's Avatar
www.upgrademotoring.com
It takes about 2 weeks to a month for him to get it in to him, then shipping from South California... unless he has it in stock, I think he only stocks the FPRs though.
