This is a discussion on Grip vs. Drift - The How and Why to Understanding Slip Angle Dynamics within the TECH Discussion Forum forums, part of the TECH Discussion category; --In auto racing, slip angle is the angle between a wheels actual direction of travel and the direction towards which ...
Large Member
Drift Science - The How's, Why's, and WTFs to Understanding Slip Angle Dynamics
--In auto racing, slip angle is the angle between a wheels actual direction of travel and the direction towards which it is pointing. The more slip angle the more side force a wheel will generate - this is true up to a certain maximum, typically around 4-8 degrees, where the side force will start to drop off again.--
Hello, fellow drifting.com members. I write this today to explain one thing that is often confusing to newbies and even those who are already drifting. It is the old grip vs. drift arguement. As many of you already know, there is a time and place for each. Drifting is not just used for fun and to keep the revs up and waste gas. Drifting can be fast. It is widely known that with some slip angle, usually still considered grip by most racers, tires can really grab the road better. One basic rule of thumb is that if you can take the fastest line at near wide open throttle or at wide open throttle and keep in grip, you should never drift on that corner (dynamic drifting doesn't have much of a place here). Another rule of thumb is that (I know this thanks to malcolm, GridRaceTech, and Ryan) the best slip angle for radial slicks is around 1-2degrees, for bias-ply slicks, around 3-5 degrees, for DOT-R compound tires (rather like drag radials or street-legal racing tires), around 5-7 degrees, and for street tires, anywhere between 4-9 degrees. An example is at a chicane. If you rotate the car on corner entry where you would normally already be turning in and on the gas, you can hold this until the middle point of the chicane. Why would you do this? Well, with a simple short moment off the gas and perhaps a dab on the brakes, the car will automatically swing back around for the corner and you can slowly let off the gas and retain grip ASAP after the apex for corner exit. After corner exit, you should be flooring it, so don't try to drift here. Always remember to take the best line along the chicane, as straight as possible, rolling over both curbs (remember to keep it stable here ). Becuase of the fact that you only want a bit of slip in a straight line, at corner exit you dont want to have the rear tires hanging out, but you do want to have the car rotated which is the whole point of drifting. Well, that and fun. Unfortuneately, I had trouble while uploading a picture of this but you get the point. at corner exit the car should never keep rotating after you are facing the correct direction UNLESS you are going to the outside for the next corner going the opposite direction (like a chicane with a straight in between).Another important thing to understand is the under normal cornering, parts of the tire are already slipping a bit since it is as if your tires is a drivetrain with a locked differential. The inside of the tire cannot rotate slower than the outside, thus causing slip. With front-wheel STEERING, the rear tire's contact patch gets this amount of slip in a diagonal pattern, starting at the inside rear portion of the tire, even moreso on the outside tire since it is travelling faster and the outside-inside of the the tire's slip ratio is the same and therefore the higher the speeds (the outside tire travels fast with a differential on the car), the faster the outside of the tire must travel and, to a LESSER extent, the inside portion of the tire (depending on camber, caster, and other alignment settings). This is an elementary version of slip angle. With HICAS (four-wheel steering), the same principle applies except the slip effect isn't as diagonal and it is moreso starting from the back and heading to the front of the contact patch. A drift is defined as the point at which the ENTIRE tire gains this slip effect and the car begins to rotate. The more you break traction at this point, the greater the slip angle. Here are some examples of exhibition (slow) drifting. it is only done for spectators, not speed. ![]() ![]() In the picture below, Ueo Katsuhiro (in the hachiroku) has a very high drift angle whereas the driver of the 240 behind him is demonstrating a somewhat fast but still an exhibition drift. This is quite often used to catch up to the person in front of you during Tsuiso. ![]() The Hachiroku in the picture below is demonstrating just 1 or two degrees of drift angle, the perfect angle for most cars near corner exit. ![]() Cars with bias-ply slicks benefit from slightly more drift angle like the one below. Keep in mind that I am NOT saying that this MR-S has bias-ply slicks, but its drift angle is about appropriate for such a tire ![]() Can't stress this one enough people, NO. ![]() The cars below have drift angles slightly beyond the drift angle that is desirable and beneficial to most racers. However, on lower traction surfaces or on street tires, this is the perfect race drift angle for the turn shown. ![]() ![]() Picture this: Petter Solberg (famed WRC driver, almost killed his co-driver in Rally Deutchland; actually he escpaped without a scratch even though he was almost crushed by [this will suprise you] the rollcage) is drifting a corner (in an AWD, mind you) covered in snow. it has a 90 degree turn (which he is on), a short straightaway, and then another left-hander. What he will do is rotate the car slightly before normal corner entry and power through with minimal steering work. With the AWD system, this is all very fast and his drift angle will stay constant (by this I mean as seen from above, the angle will decrease slowly to zero in relation to the road ahead as he rounds the bend. He will almost floor it (for traction purposes), then brake for the next corner and do the same thing. This also demonstrates how on slippery, gravel, and snow covered areas with low traction, the optimum drift angle can raise up to as much as 20 degrees on some street tires. ![]() This time a different car is on dry, hot tarmac. He does the same thing except without the straightaway in between. This is hardly a drift. It is simply a controlled spinout which also involves flooring it afterwards and travelling 10 feet to the left while he's at it. ![]() This time a video of the same type of corner. Ignore the minimal countersteering due to AWD. http://s92836226.onlinehome.us/filmy...owerslide.mpeg The same type of corner demonstrated in a different car at a different angle. ![]() This is another demonstration of an appropriate corner exit drift angle on tarmac, this also applies similarly to RWD ![]() This is an actual, real-world use for high-angle, slow exhibition drifting. The FD in front is trying to block the other FD from passing by taking up too much space and blocking all of the fastest lines. ![]() There is also another variable here. With all the weight shifting and slip being uneven throughout the tires under grip, traction can be upset very easily from (and I'm quoting Malcolm here) a small crack in the pavement or a little pebble. This sudden onset of oversteer or understeer or excessive four-wheel sliding isn't as violent when drifting. The higher angle the drift, the more this is true. But, because of reduced grip, there is a dropoff point when these benefits become useless and, in fact, damaging to your speed and possibly to your car. Yet another reason to drift slightly is weight transfer throughout the contact patch. Yes, weight transfer throughout the contact patch. Picture the tire as mostly gripping. There is a diagonal path of where the slippage passes the point on the tire with the most work being done. During a full drift (at a few degrees of yaw) the weight is evened out much better and the uneven speed of the tire is essentially fixed. This can be compared in the exact same way to giving some gas to a car with a locked differential. And that, my friends, is how slip angle works. Plus, you get the benefit of rotating the car without some ridiculous 90 degree four wheel steering (well that's a thinker, I wonder if that would work. You would need two steering wheels but that's no problem. If you have multiple arms like that dude in Spiderman 2 or whatever). If you want more reasoning, lets look at the traction circle. ![]() As you can see, 1g of braking, acceleration, or raw turning can be used at once on this hypothetical car. However, you cannot utilize 1g of braking force and 1g of turning force at once, amounting to 2gs. This would make some people assume that the cornering force and braking or acceleration force can only amount to 1g. WRONG. If you look at the square in the top right quadrant of the traction circle, you will notice that if you are to use around 65% (0.65g) of your cornering force, you can use up to 75% (0.75g) of your potential acceleration force! The reason behind this is that a tire can potentially, in a perfect world with perfect conditions (not seen on ashphalt) generate full potential in all directions at one time. However, to harness this and essentially "line up" the traction circle with your car, you need some slip. Now I know what you are all thinking: 2 things. #1: if you can only utilize 65% of your cornering force, then won't you run off the road/track? #2 What about the rules of dynamic and static friction? Won't the slip just cause you to slide away into the junkyard? Well, in regards to #1, you just need to brake earlier. If you brake later then a pro racer does, you won't be able to use any throttle and you will run to the outside of the turn and, as you slow down from cornering and friction, you will run back to the inside and you should be fine. If you brake earlier, then you can utilize the entire potential of the traction circle if done correctly. Now why would this slow entry speed, high exit speed pay off in the long run? You will take the proper line. You won't slowly run to the outside and back in again. You won't hit an early apex on a regular turn. That is what will shave precious seconds off your lap times. #2 This is the reason why you can't have the best of both worlds: 1g of acceleration + 1g of cornering. Because of the necessary slip, you can only corner (with the car demonstrated by the traction circle above) with up to 1.4g as opposed to 1.42g approx. (once again, thanks for clearing this up malcolm, I was quite tired when i wrote this section). It is 1.42g because of the approximate 45 degree angle between the acceleration and cornering force in the traction circle therefore you can add 1g + 1g together to get 2g, and then find the approximate square root, giving you about 1.42g. However, this is where the slip is required. This is also why it is not a traction square .I hope this has been helpful to you all in understanding the dynamics, reasons, and overall science behind drifting. You must also made sure that you do not mix up AWD and RWD, although, as you can see, there are very striking similarities since AWD drift is basicalle a useful form of partial understeer. In a way AWD is like having high grip with low traction. My conclusion is that, in reference to the idea in the beginning of this writeup about slip angle under complete grip (along the contact patch), small amounts of drift essentially help straighten out this contact patch thus increasing lateral traction therefore allowing for tighter steering angles. This is the concept behind the four-wheel slide. That, coupled with the rotation of the car, is what makes drifting faster on some curves. To sum it all up, go out there and try grip first. Once you have learned about taking correct lines, practice these techniques to find appropriate angles on each corner. You will find your lap times disappearing like Eddie Murphy after Delirious. After this you can learn how to use multiple angles on different corners and take advantage of late and early apexs and keep in control and, most of all, have fun! Note: Some cars don't require such slip. For instance, Formula 1 cars never drift; not just because of near-perfect traction control coupled with drivers like Schumacher but they are set up perfectly within the restrictions and guidelines (I hate those). They also lose 50% of their downforce at 5 degrees yaw. A car that performs best under grip is a VERY good car. Yet another bunch of elements contribute to optimum slip angle and turning technique: alignment settings. These include steering axis inclination,Dave Point/steering axis point, camber, caster, toe, and individual toe on cornering. Although the Dave Point has to do with what kind of slip angle you want, I mentioned already how camber, toe, and other alignment settings change your optimum slip angle and how your contact patch is not always even. We racers sometimes like to call it the steering axis point or simply refer to the adjustment necessary if the SAP is offset, an adjustment to the "steering axis inclination". This can help scrub radius and many other handling characteristics of the car, or make them worse if you don't know what you're doing. Always remember to trust your mechanic because something might happen on the track one day and you front brakes will fail and the rears will lock and you will lose control like that one day at the track a few years back. Anyways, I am going on a tangent now so if you want more alignment info, check out this site. It is a must-see for newbies: http://autotech-training.com/Alignment/Alignment.htm Anybody volunteer to make a glossary for this thread? Special thanks to malcolm and Ryan for helping me improve this thread with their helpful posts in other threads as well as this one. Also, thanks to Craftsman and Dave Coleman; Dave Point. Last edited by scirocco; 09-12-2004 at 12:33 PM. |
what happened to the pics?
Large Member
there we go i was able to find a proper image hosting site, www.myonlineimages.com. Now this page is up and running.
just out of interest, who here thinks that this should be stickied? Last edited by scirocco; 08-29-2004 at 04:19 PM. |
Eh.
A for effort.
I'm allergic to stupidity. If exposed, I may begin to insult the cause repeatedly. |
Large Member
Why only for effort
? seriously though, i need some constructive criticism here. Did you not like the way i wrote it or was it hard to understand or was it not long enough or what?
The truth is that you never really touched on slip angle dynamics. You didn't touch on why tires deliver the most grip at certain slip angles, and you didn't even show the traction circle. The traction circle is absolutely critical when talking about slip angles. Malcolm, Ryan, and I have all discussed this at length, so feel free to copy and paste from our posts. (Just make sure to give credit where credit is due.)
Large Member
well maybe i shouldn't have called it that then... the point of it was to explain my points of view.... perhaps i can complete with quotes from people or stuff that i already know... i did not completely finish it actually... if you mean that i should have talked about why this is so then maybe i will add that
the best was the old bristish gp races were they would get side ways just to block a faster car haha
what pricks.
Large Member
lol i love playing dirty in races and pissing people off behind me... i even used to do that in go karts.... kind of manji drift or whatever in front of people... they cant pass you but they gotta slow down.... people didn't like me
one thing you should mention is that optimum slip angles in deformable surfaces are far greater than sealed surfaces. Watch a gravel rally, and you'll see slip angles of about 15 degrees. But when you watch Formula cars, GT cars and Prototypes, their slip angles are only about 1 degree (essentially inperceptible).
I'd also suggest using what Ryan, GridRaceTech and I agreed on about slip angles for each type of tire construction. Radial Slicks: 1-2 degrees; Bias-Ply Slicks: 3-5 degrees; DOT-R Radials: 5-7 degrees. (I am not sure about street compound, as I have never really taken a car on those tires to the limit... however, I would assume that they are best at just a little more angle than DOT-R's). Also, the MR-S in your pic isn't on Bias-Ply tires... it's on street radials. The only Bias-Ply tires I think you can find are Goodyear Sports Car Specials, Stock Car tires (Goodyear, Hoosier, American Racer, etc, etc), and maybe a historic tire manufacturer that makes tires for restored 1938 Ford coupes or something like that. :P You should rethink your math there for a second too.... one lateral, plus one longitudinal equals the square-root of 2 (1.51 something... I think) that is 45 degrees between the two. It's one of those "one-one-root2" triangles that you must have learned about in highschool math. Remember, you add vectors tip to tail, and 1+1 only ever equals 2 if the vectors are in the same direction. ![]() tonesdef, which gp's are you talking about? I've never heard anything about drivers drifting to block other drivers in any races. Doesn't sound like a good move to me. It would be better to take a tighter entry to not allow them to pass you on the inside, and then take the corner a little slower, and make sure you get a good run onto the next straight so they can't slingshot up the inside on the exit of the corner. You might want to drift the car (using the specs above for specific tire types) ever-so-slightly on entry, so you can get a straighter run out of the corner. As for the part about the chicane, drifting isn't the best way through most chicanes. Actually, cornering at all usually isn't the best way. Straight-lining over the kerbs is usually best. Case-in-point: I was out doing a little private instructing for a guy in his S2000 and 911 C4 (the S2000 was WAY more fun than the 911 C4 by the way, but that's another story). There was a corner that had been turned into a chicane. It was an easy right, followed by a tight left and a tight right. He was trying to make the chicane 3 connected corners, and apexing at each kerb. I found (after asking permission to go over the kerbs in his car), that once I turned in for the first right, that it was way faster to hit the gas hard and go straight over the kerbs, and just dab the brakes before turning into the final right hander in the chicane. This was much faster because I didn't have to worry about the car getting upset over the kerbs while cornering, because I was just going straight (therefore, I could jab the gas, and hit the brakes, whereas he could only coast through). That enabled me to drop my laptime by almost half a second. This wouldn't be a good strategy for a circuit with tall kerbs, but shallow ones, like on most modern circuits, you need to cut them like crazy. Your ideaology would work quite well in a medium-speed S-curve, however. Brake, turn in to the first corner while letting off the brakes, allowing the tail to drift slightly. Ease onto the throttle to balance the car through the first corner. Just after the first apex, lift off the throttle abruptly, and brake if needed. As the weight transfers to the front, start to turn into the second corner, and allow the weight to also transfer to the other side of the car. This will cause the car to drift in the other direction slightly. Only allow the car to drift toward the apex of the second corner. At the apex, reel the drift in and grip out of the corner. The advantage of that slight drift is that you can trail brake into the corner, and already have the car rotated prior to the apex. That means you don't have to rotate the car as much after the apex. Therefore, by looking at the traction circle, you can have more longitudinal g-forces (acceleration) because you have less lateral g-forces (cornering) on the exit of the corner. More acceleration is a good thing.
Large Member
First of all, sorry about that deformable surfaces thing. I thought I went over that. There was so much to write that I would start on one thing before finishing another. I will add the part about the optimum slip angles for different types of tires on tarmac. And about the chicanes, I assumed that people already knew that the straight line is best, it's just common sense. I was strictly talking about slip to aid you in rotation for the next corner, I guess I will add something about that for that section. also i guess i should have been clear about the mr-s. I was talking about the drift angle being about apporpriate for a car with bias-ply slicks. By the way, thanks for all this help in making this a better write-up. I'll be sure to give you lots of credit at the end of the post.
Large Member
wow not as many people are reading and commenting on this thread as i expected. I think there's some useful info in there and some nice pics
You *#$@ing forgot to mention the #*$@ing Dave's Point... I'm going to give you negative recommendations until you add Dave's Point to your article...
Dave's Point is in SCC I think 1999... Do a search on it in Google. That should bring something interesting for you to add to your article... Dave Coleman is the man! I refuse to let the Dave's Point be left out of the driving history books... Matt. |
Large Member
http://www.sportcompactcarweb.com/ed..._technobabble/
Okay, I have found and read the article. I have already mentioned "weight transfer in the contact patch", which is basically what Dave is talking about. Although the Dave Point has to do with what kind of slip angle you want, I mentioned already how camber, toe, and other alignment settings change your optimum slip angle and how your contact patch is not always even. Unless you have another point that is perhaps deeper than this article, I will not post it in the actual post. Thank you for the info anyways, I highly suggest that everybody reads about the Dave Point, just not in this article. FYI, we racers sometimes like to call it the steering axis point or simply refer to the adjustment necessary if the SAP is off, an adjustment to the "steering axis inclination". This can help scrub radius and many other handling characteristics of the car, or make them worse if you don't know what you're doing. Always remember to trust your mechanic because something might happen on the track one day and you front brakes will fail and the rears will lock and you will lose control like that one day at the track a few years back. Anyways, I am going on a tangent now so if you want more alignment info, check out this site. It is a must-see for newbies: http://autotech-training.com/Alignment/Alignment.htm Last edited by scirocco; 09-01-2004 at 08:09 PM. |
#15 |
It's a joke, I might sound like a prick, but I'm just a real big fan of Dave Coleman. I found your article to be very helpful also. It was a good refresher on Slip Angles...
Matt. |
#16 |
Large Member
lol thanks dude, but that is still very helpful info
#17 | |
Location: Gunma ... ok maybe not Gunma though it be cool
#18 |
Crazy Norwegian
Quite good topic, allthough a bit too theoretical for most rookies I suppose. To fully understand the physics of a race car, you must go into equal detail on every other part of the car as well. Not even racers get that technical. That's why they have race engineers
![]() Still, I really second the advice to go grip before drift. I come from grip racing, and adapting to drifting was quite easy. I know the lines, I'm used to the speeds and I have decent car control. So it was just a matter of adjusting my style. I see so many drifters that lack the basic skills. They enter the corners at the wrong speeds and they're nowhere near the racing line. Looks bad... Also, I have a little off-topic story on how to take a chicane with curbs. At the Brands Hatch Indy curcuit in the UK there is a fast chicane just before a corner named clearways. Back when I raced single seaters, the curbs in this chicane was quite rough at the apex, forcing you to be careful not to upset the car while braking for clearways. On my first race there I walked the track with my team manager and we stopped to have a look at the chicane. We then found that there was a few inches on the inside of the curb that where quite smooth. We then saw an opportunity to be a little crazy ![]() So what we did was to replace the skid plate underneath the car with one that was twice as thick. We went out to qualify and when I got to the chicane I did what we had planned. I actually aimed for the curb head on. The curb was wide, and I could actually get the rough part under the car without having the inside wheels on the grass. Instead, the floor hit the roughest part and launched me slightly airborne in a straight line, letting me take the chicane with almost no steering effort whatsoever. I was third in that qualifying session, but that was overall. I raced a Formula Ford 1600 in a mixed field with the new 1800's! The next 1600 car started eight, more than a second slower than me. In the race, I did even better, taking the win in the last corner ![]() Those where the days...
Fredrik Sørlie |
#19 |
Large Member
thanks, man. In reference to your first paragraph, I find that many people on this site want to know this info so i decided to really get into the nitty-gritty on this one (partially thanks to malcolm) and so far the votes speak for themselves
#20 |
Large Member
If anybody else has any more suggestions I would love to hear them.
#21 |
Chas please approve.
First off Dave Coleman I LOVE YOU!
This was very informative but the people that need to read it wont take the time to read it. If anybody has ever been to autocross slip angle is very evident. Mustangs and Miatas like to come through gates sideways they have the back out 5-10 degrees the entire time it looks sweet going 60 accelerating with the back fighting to keep up. |
#22 |
Still no mention of Dave Point...
Sad ![]() hehehe... You love your thread here, don't you? ![]() Matt. |
#23 |
Large Member
lol so you've noticed how whenever this thread is dead for a few days, I post something.... damn... btw check the thread near the bottom of my post
#24 |
hahaha. Thanks homie...
You should use it to explain the scrub radius and stuff like that though. You can also explain torque steer with it. It also helps explain why drifting comes natural to some cars and not to others. When you throw your car into a turn and your steering turns by itself into the turn, that's the Dave Point in action. It's the point of the tire where the scrub radius ends. This point coincides with the arms or something of that sort. I don't exactly know what it means, so someone help explain it here. Matt. |
#25 |
Large Member
Wow, you are absolutely right. Since I already know how all this works I never thought of how not everybody here is as knowledgable as you or me. I will definitely post the alignment link and the Dave Point links, but I'm too lazy to do any explaining myself... think I'll just copy and paste from that old post. By the way, I was just screwing around, I realize how dumb it was to just put "Dave Point" in the middle of it, I was just joking. You win. It's in the thread.
