Best S14 wheel offset?
This is a discussion on Best S14 wheel offset? within the TECH Discussion Forum forums, part of the TECH Discussion category; Hi, I would like to know what is the best wheel offset for an S14 in 17inch. I will think ...
Old 09-09-2004, 07:11 PM   #1
tr_racing
Hi, I would like to know what is the best wheel offset for an S14 in 17inch. I will think about the 5zien FN01R-C whit this wheel:
17x8+25
17x9+35
Thanks for your advice!
Kevin..
tr_racing is offline   Reply With Quote
Old 09-09-2004, 07:13 PM   #2
Brian
Brian's Avatar
17x9 +15
anything higher offset is no good.
Brian is offline   Reply With Quote
Old 09-10-2004, 06:39 PM   #3
tr_racing
Thanks man!
Old 09-11-2004, 08:31 PM   #4
chmercer
that sucks. +35 on a 9j is going to be totally sunk. you want 17x10 +12 run 225/45, or if you are really cool you will get 18x9.5 +12 all around. dont get thoes lame as.s sizes you posted.
chmercer is offline   Reply With Quote
Old 09-12-2004, 09:07 AM   #5
tr_racing
Ok the Size i post is the size recommend by 5Zigen! I post it because i'm not an expert in wheel and people help me! So thanks a lot for your information.
Kevin..
Old 09-12-2004, 02:06 PM   #6
Brian
Brian's Avatar
dont forget that there are many factors taht go into the final outcome of how the wheels will look and fit.
+offset
+tire size
+ride height
+camber
+caster
you really need to play with all the settings to get the wheel/tire to fit perfect.
Old 09-13-2004, 08:05 AM   #7
tr_racing
+offset
+tire size
+ride height
+camber
+caster
Ok i thing to put 17x8+20 in front 17x9+15 in rear whit tanabe sustec pro DD coilover, Z32 front brake in front, and camber:i dont know what is the best, now i m in factory camber!
Kevin..
