rb swap in 92 240 coupe
This is a discussion on rb swap in 92 240 coupe within the TECH Discussion Forum forums, part of the TECH Discussion category; my friend is getting a 92 240 and he wants to put in a rb26 motor in it what r ...
Old 09-13-2004, 01:43 PM   #1
70gtodrifter
70gtodrifter's Avatar
Send a message via AIM to 70gtodrifter
my friend is getting a 92 240 and he wants to put in a rb26 motor in it what r some tips u smart people can give him
70gtodrifter is offline   Reply With Quote
Old 09-13-2004, 01:51 PM   #2
M5-Drifter
Z.I.S. Team Driver
M5-Drifter's Avatar
Send a message via AIM to M5-Drifter Send a message via Yahoo to M5-Drifter
I wouldnt do it lol, rb26's are heavy, go with the sr20 def, its light, great for drifting, and you can still get it fast. So thats my tip, but if he wants to do it, go for it, but expect a big weight gain.
M5-Drifter is offline   Reply With Quote
Old 09-13-2004, 01:59 PM   #3
Parry
Parry's Avatar
rb in a 240?
What does he want to build a rocket sled? If all he wants to do is go fast he owns the wrong car.
Old 09-13-2004, 07:42 PM   #4
70gtodrifter
he isnt sure if he wants to put in a rb25 or 26 but he wants to be different from everyone else who has sr20s
Old 09-13-2004, 07:53 PM   #5
M5-Drifter
Z.I.S. Team Driver
M5-Drifter's Avatar
I know some people put sr20's in to "be cool" and be like everyone else, but, there is a good actual reason for having an sr20 too, its perfect for drifting, its light weight, its what was meant to be in the silvia, and its just a wise decision to get one. Rb26 or 25, no matter which one, an sr20 would still be a better choice.
Old 09-13-2004, 08:24 PM   #6
Parry
Parry's Avatar
He wants to be different?
lol then he really did buy the wrong car.
Old 09-13-2004, 09:32 PM   #7
wookie512
wookie512's Avatar
Send a message via AIM to wookie512
there was these guys that did a rb26dett swap into a 240 fastback up here i think. i was talking with one of the guys at Autovasion and correct me if im wrong, but, i think i heard him say it took them about 2-3 days to finish the swap and all the wiring and still have enough time to finish the body work. he told me it was for show, it wasnt for go. way to much weight in the front.
wookie512 is offline   Reply With Quote
Old 09-14-2004, 12:21 AM   #8
totoro001
i know a few people now who have done this, and there are plenty of reasons to do it.. wether it's more HP potential or just for bad *Censored**Censored**Censored* factor, there are plenty of reasons to do it. don't let these nay-sayers detour you or your friend from the idea.. there are some things to consider however. you'll need motor mounts (if you use the stock crossmember it'll have the engine hitting your hood). if you stick with the TT setup, you'll need a custom manifold made, otherwise it's going to hit the steering column (in JPN the steering column is on the other side so this isn't a big problem). you'll also need a custom driveshaft made to go from the rb25det tranny.. which by the way, you'll also need the rb25 tranny to bring you from AWD to RWD. the rb26 oilpan is too deep, so you'll need the rb25 oilpan.. you'll also need to either consider going standalone ECU, or use the rb26's ECU. obviously this is nowhere near sa cheap as the SR swap.. the motor alone is going to start you at around 3500ish for the r32 rb26, then you need to find the rb25 tranny and oil pan.. or you can just go rb25 and then all you'll need is mounts and a drive shaft..
now i'm also leaving out the slew of custom piping (depending on what IC you're going to use), and the fact that there are few places that know how to get the stuff like the AC working, especially with the rb's computer and the ka's heater controls. that sort of thing.. buuuuuut most people don't spend 6 grand on a motor install so that it runs the AC better, so i'm doubting you or your friend is too concerned about that.
if you need help finding a clip and stuff, email me and i'll see what i can do
Old 09-14-2004, 09:28 AM   #9
Darkstar
Post idiot
Darkstar's Avatar
As higher. The RB25 would be definately easier to swap, as you will not need to run a custom exhaust manifold and/or turbos. Another way for extra power (altough little less than in the 25) would be the RB20DET. It's also a good engine, and the swap is still easier than the RB26 one.
Old 09-14-2004, 07:03 PM   #10
70gtodrifter
what does the rb20 come out of
Old 09-14-2004, 07:19 PM   #11
drift matic
touge artist
drift matic's Avatar
i would recomend the rb20et because a rb26dett is a hella lota wait on the front end
drift matic is offline   Reply With Quote
Old 09-14-2004, 07:22 PM   #12
Ghost of Duluth
Sixgun
Ghost of Duluth's Avatar
Same thing that the RB25's and 26's come out of, just an earlier year.
The 26 is gonna be a ton of work, listen to the guys above. Same with the 25. The 20 however, is still some work but not as much. My brother makes the mount kits, they fit the 20, 25 and 26's. There should be a couple cars at the Atlanta meet that are running his mount kits, I think a couple of the RB26 cars are gonna be there. He can make you the manifold as well. www.tophatperformance.com. His mounts will allow you to run the strut tower brace without having to modify the oil pan. The RB20 isn't all that fast from the get go, it just has a load of potential. Same with the SR swap. Factory, unmodded SR20 and RB20 swaps are not fast. My FD buried my brothers first RB20 swap and I mean burried it off the light and all the way up. Within an 1/8th of a mile, I was at least 5 car lenghts ahead. Mine is modded but tell your friend that just because he gets this swap, don't go out trying to be Superman cause it ain't happening. He needs to understand this right now. They are faster than a KA for sure, but in the grand scheme of things, they are not fast. Now, if he wants fast, he will need to be prepared to spend the big bucks.
They also shouldn't make too bad a platform for sliding either, they will position the weight more towards the front allowing the rear end to break easier, but harder to control at higher speeds due to being off balance. Just my thoughts on that.
Old 09-14-2004, 07:54 PM   #13
OH240SE
Flatland Honky
OH240SE's Avatar
yup, as always here's something else that's been said before....again...
U toss an RB in a 240 and it'll screw up the weight balance.
If u want to be different and u have the money, cool.
But if u have enough money and enough know-how to throw a big motor like that in a little car, u might as well find a better chassis to fit it so it's balanced.
Only reason to put an RB in a 240 in my opinion is to make the 240 a drag car.
Tell ur friend he's dreaming and to come back to a logical reality.
Old 09-15-2004, 05:31 PM   #14
70gtodrifter
thnx for the advice so far he just got the car today so the project is starting soon ill keep u guys posted on the progress
Old 09-16-2004, 09:16 AM   #15
slideways2004
slideways2004's Avatar
allright here's what i gotta say-
if he wants to be different, then he definetly has the wrong car like others above mentioned-
if you were to do a rb swap i would go with the rb20 if you dont mind upgrading some stuff like torbos and stuff-
rb25 if you want to leave evrything stock like bottom end, turbo, etc.
the rb25 doesn't mess up the weight balance, it just changes, which is not a bad thing, and you can keep it close to ka front end weight by getting FRP or C.F. fenders, hood, bumper.
if you want to go rb swap, you will need a mickeney or other custom motor mounts to position the engine far back and low enough to keep good weight distribution
also if you go rb20, you don't need a custom driveshaft, you can use your stock one, rb25 you need custom
also did you guys not see that vid of the red coupe w/ rb25 at DD
i forgot which forum i seen it on
slideways2004 is offline   Reply With Quote
Old 09-16-2004, 11:38 AM   #16
NismoSigma
Driftin' to the MOON!
NismoSigma's Avatar
Send a message via AIM to NismoSigma
If you wanna drop the rb your going to have to fabricate diffrent parts for the 240. The rb is awd, the 240 was meant for rwd. He would than have to be putting alot more weight on the car. Go for a ca18 if you wanna be diffrent.
NismoSigma is offline   Reply With Quote
Old 09-16-2004, 12:18 PM   #17
slideways2004
only the rb26 is AWD. the rb20+25 are RWD. you can use the rb25 rwd transmission in the rb26
Old 09-16-2004, 01:54 PM   #18
Darkstar
Post idiot
Darkstar's Avatar
Meeeep!
Wrong. There is one more AWD Skyline. It's an RB20DET-powered R32 GTS-4. It has HICAS and ATESSA E-TS. It's nearly the same as the GTR, except the motor, the brakes and suspension components.
Exactly. An RB25-powered S13 once won the D1GP series Japan, so I don't think it messes it ups that much.
Old 09-17-2004, 05:44 AM   #19
slideways2004
he he thanks for the easilly forgotten info that i, well, forgot.
when you think of the beast rb26 awd skyline you forget all of others, even if it is another skyline
Old 09-22-2004, 03:26 PM   #20
70gtodrifter
so heres the deal he desided to go with the sr20det because it goes in cleaner and he is going to put a silvia clip on it so the motor will be rite to the car
Old 09-25-2004, 12:42 PM   #21
240silvia
240silvia's Avatar
Send a message via AIM to 240silvia
i wanted to do the same thing, not put a rb26dett, but to be different, when these guys say it will be a mess up, they are right, even if u want to drag it, u might want to make it front wheel drive, which will costa shieeeet load, so what i did to be "different" was add Individual Throttle Bodies with a tank, ask him if thats cool with him, it takes off a ton of spool up time to the turbos, there are also twin turbo kits available for the sr20, u just need to look around, just come up with different ideas, u guys are doing well, just do more research!!
good luck
240silvia is offline   Reply With Quote
Old 09-27-2004, 07:57 PM   #22
Ris4drift
want somethign different?
how about using common sense unlike the other 80% of people and just going ka-t. cheaper , faster and more practical. do some research before you go wasting all your money.
another couple alternatives already mentioned are ca18, they can go for dirt cheap thanks to the sr20 bandwagon that everyone is wasting their money on. rev high, strong bottomend. cheap. but you will have fun whensomething breaks, b/c parts arent readily available at oriellys/napa.
rb25det+mkinney mounts. freind did it in his s14, i was bored pricing stuff the other day, can almost be done for price of SR, but unlike the SR will have torque. but like ca have fun getting parts anywhere you want.
or like i said at 1st, for 1/2 the price of what a complete sr clip will cost you can do ka-t, and have more torque and power than sr.
Old 09-28-2004, 01:30 AM   #23
Darkstar
Post idiot
Darkstar's Avatar
Don't forget that the CA is sometimes called "the little RB" because of a cast-iron block, not aluminium like in SR20 motors. As Ris4drift has already written, it has strong bottom end. There's one CA18-powered RS13 in the UK which pumps out as much as over 600hp, and can be street driven (it had first been built by Norris Designs and then sold to a private owner). If I remember good, Jun's SR20-powered S14 record-holding drag racer posted around 700, and it couldn't be a daily driver. Simply rethink the CA18 engine, as it's waaay cheaper than the SR20 and has similar power potential (if you look for it, of course).
I would personally go with RB20DET, as this one's easier to swap than the other RB's, has some power potential, and - most importantly - is a six banger, which makes the work smoother and the work stroke more effective (note here: that's because the cylinder capacity is smaller compared to any 2 liter four-banger like the SR20).
