This is a discussion on 89 240sx coupe rear disc brake, HELP!!! within the TECH Discussion Forum forums, part of the TECH Discussion category; Ok, I've just bought an 89 240sx coupe and both rear brakes are almost out, I finished pulling out the ...
Ok, I've just bought an 89 240sx coupe and both rear brakes are almost out, I finished pulling out the nuts/bolts from the brake pads and disassembled it. The problem is I bought new brake pads but when I put them together there is not enough gap space for the rotor? Do I need to use a C-Clamp to push out the brakes or what, PLEASE HELP!!! I need to use my car. Also does the 89 240sx coupes comes with ABS, my car is an SE model.
Anyone?
another 240 owner
no the 89 coupe does not come with abs.i just replaced my front rotors on my 89 coupe 2 days ago.im not sure waht to do about the spacing cause my pads fit great.sry.
Drift Assoc. - Lead Tech
No ABS you have to screw in the piston... needle nose pliers work great for that. There are 4 notches that allow you to get a grip on the piston to turn it in.
