gauges and SR motor.....
This is a discussion on gauges and SR motor..... within the TECH Discussion Forum forums, part of the TECH Discussion category; hey guys, i was wondering are the USDM 240 guages compatible with the SR motor???.....dont know if this was asked ...
Old 09-22-2004, 12:34 AM   #1
180sxdorift2
180sxdorift2's Avatar
hey guys, i was wondering are the USDM 240 guages compatible with the SR motor???.....dont know if this was asked already, if so, 4give me.....thx 4 ne help
180sxdorift2 is offline   Reply With Quote
Old 09-22-2004, 12:45 AM   #2
GoukiS14
Subway Pervert FD
GoukiS14's Avatar
Location: Back in the U.S. but wishing he were back in Japan
yes they should be as long as you use the correct year w/ the correct sr equipment
GoukiS14 is offline   Reply With Quote
Old 09-22-2004, 07:48 AM   #3
LOVMUFN
Drift Assoc. - Lead Tech
LOVMUFN's Avatar
You need speed sensor from KA tranny for speed to be accurate and the SOHC tach does not work correctly with the SR.
Old 09-22-2004, 09:24 AM   #4
Darkstar
Post idiot
Darkstar's Avatar
The gauge cluster is compatible, but since the SR revs and redlines higher than a KA24 (both SOHC and DOHC) I would reccomend swapping the JDM gauges complete with the motor.
Old 09-22-2004, 09:36 PM   #5
SilverGhost
touge sleepy-eye 180sx
SilverGhost's Avatar
but technically you can use the gauges, right? i have a 91 se thats gettting sr finished up this week, so i will be ok, right? the tach goes to 9, so i will just have to know that red is 8, and can make a new face plate for my tach that moves the redline to 8 rather than 7 but use the same tach, right?
*sorry for all the rapid fire questions*
Old 09-23-2004, 12:55 PM   #6
LOVMUFN
LOVMUFN's Avatar
yes, just change speed sensor in tranny or you will be putting a km/h signal to a gauge that reads mph.
