rb25det in s14
This is a discussion on rb25det in s14 within the TECH Discussion Forum forums, part of the TECH Discussion category; ok heres the deal i have an rb25det front clip with tranny.. what do i need to put it in ...
Old 09-28-2004, 02:48 PM   #1
s14jun
Send a message via AIM to s14jun
rb25det in s14
ok heres the deal i have an rb25det front clip with tranny.. what do i need to put it in my s14??? im hearing things here and there thati would need a custom drive shaft and motormounts.. i dont mind the motor mounts but the drive shaft?? i cant use the one from my 240??? please i would like to know everything about this swap.. everything
s14jun is offline   Reply With Quote
Old 09-28-2004, 03:14 PM   #2
s14driftingTX
#1 F1 Fan
s14driftingTX's Avatar
http://www.sportcompactcarweb.com/tech/0309scc_hybrid/
s14driftingTX is offline   Reply With Quote
Old 09-29-2004, 11:25 PM   #3
rb25jun
rb25jun's Avatar
im s14 jun... i already seen that its just the drive shaft im worried abour thats all.
rb25jun is offline   Reply With Quote
Old 09-30-2004, 06:30 AM   #4
tr_racing
Look at mckinneymotorsport.com they have a lot of stock for RB swap into a 240sx!
Kevin..
tr_racing is offline   Reply With Quote
Old 09-30-2004, 07:52 AM   #5
Darkstar
Post idiot
Darkstar's Avatar
http://www.drifting.com/forums/showt...&threadid=8310
Could be useful I suppose.
Old 09-30-2004, 07:58 AM   #6
Hump-D
D@mn you're lazy.
The RB25's transmission is slightly longer, and the output shaft slightly larger than the 240SX, so a new driveshaft is needed. If the Skyline's driveshaft yoke was included in your clip, slide it into the transmission and shove it all the way forward. Then bolt the stock driveshaft to the differential and let it hang. Measure the distance from the center of the U-joint on the diff to the center of the U-joint on the back of the transmission and--this part is important--subtract 1 inch to allow for driveline movement. Take all the pieces to a driveline shop and tell them "I want this yoke (Skyline) and this rear U-joint (240SX) on a one-piece driveshaft this long (your measurement)." Then give them money (probably a few hundred bucks). If you don't have the Skyline yoke, you can use one from a twin-turbo Z.
Can you handle that? Good luck. Not as hard as hard as you think.
Hump-D is offline   Reply With Quote
Old 09-30-2004, 08:15 AM   #7
Hump-D
D@mn you're lazy.
Old 10-06-2004, 01:37 AM   #8
Ris4drift
actually you dont need to do any of that. get the motor mounts from mckinney motorsports and it fits everythign fine.
Old 10-06-2004, 06:18 PM   #9
rb25jun
rb25jun's Avatar
if all i need are the motor mounts why do they sell it with a drive shaft?? as a package.
Old 10-09-2004, 07:37 AM   #10
mk3mann
mk3mann's Avatar
my friend just completed his rb25 swap in his s14. He also put the FULL s15 front end conversion with the c-west body kit.....and cherry red...its blanging
I will talk to him ( Brandon) tommorow. And see if he will let me take some pics of his ride.....i would say he did good selling his stupid elipses and talons to make this thing. he should win some shows with it!
not to menion the advan 3 spokes...
mk3mann is offline   Reply With Quote
Old 10-09-2004, 02:41 PM   #11
Ris4drift
yah i was wrong about the driveshaft. i suck at life.
