95 infinity j30 VLSD?
This is a discussion on 95 infinity j30 VLSD? within the TECH Discussion Forum forums, part of the TECH Discussion category; As you have guessed i want A VLSD for my 90 240sx, i just want to know if all 95 ...
Old 10-11-2004, 03:15 PM   #1
Warped
Flippin nutball!!!!
Warped's Avatar
As you have guessed i want A VLSD for my 90 240sx, i just want to know if all 95 infinity j30's have that stock. i'm looking through junkyards for the unit but they don't know if they are vlsd or not. I asked a parts department at infinity and they said some have them some don't and there are no markings to tell the diff.
Old 10-14-2004, 12:20 PM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
The parts department at Infiniti is wrong. ALL J30s came with the VLSD. You are very smart to look for a '95-96 diff, because the halfshafts are the same six-bolt pattern as the 240SX's, whereas the '92-'94 diffs used a different (five-bolt) pattern.
Make absolutely sure to get everything from the diff mounting area: the two mounting bolts, the two rubber spacers, and the two rubber-and-metal spacers, as all are required.
Old 10-14-2004, 12:45 PM   #3
Warped
Flippin nutball!!!!
Warped's Avatar
Thank you very much, sorry about the double post but it seemed my other thread was misunderstood. Again thank you, now after i get the unit i should replace the fluid right. With like redline Vlsd or something?
Old 10-15-2004, 09:12 PM   #4
GRiDRaceTech
The actual differential part is sealed, so you can use any transmission oil. I used Mobil 1 75w90 synthetic in mine, but I'm not quite sure if it was the best choice. You might want to try Royal Purple.
