Freaky speedometer
This is a discussion on Freaky speedometer within the TECH Discussion Forum forums, part of the TECH Discussion category; ok i just got a 1990 240sx Ka24E, when the car is at idle the speedometer shows about 10 MPH, ...
Old 10-16-2004, 05:25 PM   #1
Warped
Flippin nutball!!!!
Warped's Avatar
Freaky speedometer
ok i just got a 1990 240sx Ka24E, when the car is at idle the speedometer shows about 10 MPH, if you rev it it goes up, as soon as you start to drive it goes normal???? Any ideas what's causing this? ....Analog Dash and it's a maual.
Old 10-16-2004, 06:31 PM   #2
M5-Drifter
Z.I.S. Team Driver
M5-Drifter's Avatar
Send a message via AIM to M5-Drifter Send a message via Yahoo to M5-Drifter
So it does work though right? I mean it shows what speed your going, but when you idle it says its goin at 10 mph? Well...that doesnt seem like it would be too much of a problem...but I have no Idea what would be causing it lol.
M5-Drifter is offline   Reply With Quote
Old 10-16-2004, 06:41 PM   #3
Warped
Flippin nutball!!!!
Warped's Avatar
i'm just concerned that it might turn into a bigger problem, and what if i am getting inacurate readings? i am also concerned about passing inspection. NY is getting more and more of a pain in the *Censored**Censored**Censored*!
Old 10-19-2004, 07:11 AM   #4
Nemesis
Boro Miata
Nemesis's Avatar
Send a message via AIM to Nemesis
check ground wires
this exact thing happened to my civic, the speedo would jump up and down while i was driving, but there wasn't any engine failures...one of the ground wires wasn't grounded all the way and was rubbing the frame of the car.(i had jus finsihed swapping in a new...err....used d-series motor) screwed the screw down tight and all was fine....
Nemesis is offline   Reply With Quote
Old 10-19-2004, 07:34 AM   #5
Warped
Flippin nutball!!!!
Warped's Avatar
thanks i'll check that out.
Old 10-21-2004, 01:19 PM   #6
bboyt3nsk
Dinosuars=Jesus Horses
make sure the wiring harness is nice and tight in your computer
