This is a discussion on No spark within the TECH Discussion Forum forums, part of the TECH Discussion category; I have an S13 with a redtop engine and doing a AT to MT swap and i got the AT ...
Dinosuars=Jesus Horses
No spark
I have an S13 with a redtop engine and doing a AT to MT swap and i got the AT wiring bypass done.... now i have no spark at all...I heard your supposed to do some splicing too on one of the plugs by the fuse box? is this true?
sleeping in traffic
The below is part of three posts sent to http://groups.yahoo.com/group/nissans13/messages under the subject heading of "Auto-5spd Info (from Japan)". Note that im not sure of the authors name or email other than his email starts with "akoasare". The author and myself take no responsibility for the information contained in this post as it is purely designed to be a free help guide.
Tsup Dude, I just did this last weekend. I have an 88 J-Spec Sylvia K. I am an American in Japan. So some of the info I have is Japan specific Parts: Transmission Flywheel *new* Throw out bearing *new* pilot bushing 5spd Drive shaft Pressure plate clutch plate $200.- I got a deal it is usually 3 to 4 bills. Clutch Master cylinder Slave cylinder - all piping between the clutch master cylinder and slave cylinder $100 - I got ripped off. The first set of part is the actual transmission The second set of parts is the hydraulic system that allows the operator (you) to actuate the clutch. I had a full garage and I had help from a guy who has done this several times. So I can't be very helpful there. -Electrical The Automatic transmission has a separate computer from the Engine mgmt computer. Don't bother looking for it. It still has a use once fully converted. In the Engine bay right behind the fuses box are several wire connectors. 1) of then tells the car when your car is in a drive gear (so you can't start the vehicle. In my car the connector was TAN. I can't say for Aussie-spec. Once you find the connector disconnect the end that goes down to the Auto. Take that end clip. You don't need it. Take the two wires and soder them together creating a loop. Re- connect the TAN connector. BEWARE this will now allow you car to start in any gear. 2) Next your will see a set of three connectors (2 grey, 1 red <- Jspec is my only reference). The middle connector is what pass the info to the Auto Computer that the car is in reverse. In fact only the Green and black/gray wires matter. The remainder of the connectors are all for the Auto. Once you put the 5 spd in you can toss the remainder -Mechanical 1) (4bolts) Start with disconnecting the drive shaft from differential. ***Do not dis connect the driveshaft from the Tranny. If you did you might end up with an ATF bath. Continued......... -Mechanical 2) Punch a hole in the ATF resevoir. Then drain out ATF. 3) Remove driveshaft 4) Disconnect downpipe (This gives you room to work) This is also an outstanding opportunity to punch the CAT. But I suspect that is not legal 5) (6 bolts?)Remove all the bolts on the bottom of the Tranny 6) Disconnect all wires connected to tranny 7) Disconnect Auto selector 8) Remove rear transmission crossbar support. It must be replaced with its manual equivalent 9) once you remove the support the only thing holding the tranny to the car will be the bolts that connect the tranny to the engine. IOW the tranny will be supported by the engine mounts. Don't worry nothing will happen. The Auto will swing down slightly. This will enable you remove the remaing 4-6 bolts on the top of the Tranny. 10) Now one would think the tranny will come off ---WRONG! 11) On the bottom between the tranny and the engine is a metal dust cover. Pull it out. You should see the Torque converter. There are 3 bolts that connect the converter to the engine. To remove all 3 bolts you will have to manually rotate the engine (not hard). 12) Get a 27mm socket and a rachet. Go to the front of the engine (near the fan) put the rachet to work. 13) Remove the three bolts and the transmission should come off. *****BEWARE the AUTO tranny is heavier than the manual***** 14) When removing it use a tranny lift 15) Once the tranny is removed remove the Auto Fly wheel - Its connected to the engine 16) Remove the Auto pilot bushing. It requires a special tool. And the tool will destroy the auto pilot bushing. But that is not a big deal considering the pilot bushing cost $2.- and NISSAN. 17) Remove the stick from the Manual transmission. It is held in place by a C-clip 18) Tap the Manual Pilot bushing in where the Auto pilot bushing was until it is flush. 19) Mount the Manual Flywheel 20) Mount clutch and pressure plate 21) Use clutch alignment tool to ensure clutch is mounted properly. INTERNAL 1) Inside the car you will need to replace your brake pedal with a 5spd brake pedal. That part is self explanatory. Pull 1 out and put the other in. 2) Next to the brake pedal you will see a template for the Manual clutch mount. 3) DO NOT remove the metal collars. Drill out the 2 holes which represent where the clutch mount bolts go through. 4) Drill out the big template/hole. It is where the clutch master cylinder will enter the car. The whole process should take you less than an hour. 5) The mounting bolt for the clutch pedal housing should be in the car already. 6) the clutch housing has two bolts on it that will go through the firewall. On the other side there housing is retained by to washers. 7) When installing the clutch pedal housing install the master cylinder at the same time. The cylinder is easier to mount if you disconnect the line that runs from it to the slave cylinder. *It makes sense once you start* 8) To remove the AT selector. remove the interior trim above it. 9) There are 2 sets of 4 bolts on the selector. Choose the outboard onces. These bolts connect the selector to the car. Once the Tranny is out and the selector is out you should see the floor from within the car. ...continued Back to the tranny install.... By now you should have the following done: - Auto tranny removed - Flywheel, clutch and Pressure plate installed - Clutch pedal and housing installed - Clutch master cylinder installed - 5spd brake pedal installed - Auto selector removed Installation 1) You are going to need to replace 2 bolts. 2 bolts off of the Autotranny. (Upper drivers side - Japanese drive on the left of the road) These 2 bolts are supports for the starter. The housing on the manual is bigger here. So before you mount the maunal tranny find bolts that can fit throught the tranny all the way to the starter. 2) Inside the 5spd tranny install the new Throw out bearing and the fork. 3) Remove the clutch alignment tool. 4) To mount the 5spd tranny has to be initially installed sideways. It won't fit any other way! Once the drive shaft enters the pilot bushing rotate the tranny into the proper position. 5) Bolt the tranny to the engine. DON'T forget to reinstall the metal dust cover. 6) Install the 5spd rear mount. 7) Remove the exhaust mount off of the Auto rear mount and put it on the Manual mount. 8) Install the 5spd drive shaft 9) Re-install the downpipe 10) Remove the 5 spd drain plug. It should be toward the front is is a square bolt 11) Go inside the car. Add ***"GEAR OIL"*** through the hole where the stick is supposed to reside. Add oil until it starts to exit the tranny through the drian plug. 12) Install the stick and the rubber boot that goes over it. 13) Re-install the interior Trim 13) Re-install the drain plug 14) Install the piping from the Master cylinder to the slave cylinder. 15) Mount the slave cylinder to the transmission 16) The slave cylinder is what actuates the fork which actuates the throw-out bearing - moving the clutch in and out. 17) Add BRAKE FLUID to the maaster cylinder system. you have to bleed it (Just like brakes) in 3 spots. REVERSE Lights 1) There are 3 connectors on the Manual tranny. The rear most one is for the speedometer. The next rear most one is the one the has the reverse lights. Connect these wires to the wires I mentioned in my 1st post. You can splice them or you can retain the orginal wiring harness and splic it into the Auto Tranny wires. TEST IT OUT 1) Make sure the reverse lights work 2) Make sure the car still starts 3) Make sure clutch pedal actuates the throw-out bearing 4) TEST DRIVE!!!! IMPRESSION: It is like night and day. I feel as though I have set my car free. I used to have that cold start stumbling problem. ALL GONE! The car is faster and more responsive. I love it! The money for the tranny bought me fun and education. I want to put the Supra 6spd in the ARISTO (GS300) now. "Good Luck, JIM!" THAT IS ALL I CAN REMEMBER. HOPE THIS HELPS. iT TOOK ME FOREVER BECAUSE THIS WAS MY 1ST TIME. THE GUY I WAS WITHSAID HE COULD DO IT IN 5 HOURS. IT TOOK ME 14HOURS - I AM SLOW!!! ****DISCLAIMER: Do this at your own risk!******* |
sleeping in traffic
i follwed for my previous S13 it worked and i didn't really have to do any thing else electrical but i didn't follow step - '2) Punch a hole in the ATF resevoir. Then drain out ATF.'
i thought that was a bit stupid destroying the ATF pan so i jacked the car up lossend the bolts and gave it a slight tap with a rubber mallet to break the seal between the pan and the the auto box with a big square pan underneith it to chatch the ATF so i didn't have to destroy the auto box http://members.iinet.net/~sayers/biscuits/index.htm |
very very nice thank you! youve helped alot of other people out here im sure
5 hours to do that?! good god....i mean this is my first time so that seems insane...but i cudnt imagine polishing off a swap and driving it in one day! LoL
sleeping in traffic
your welcome. let me guess u didn't do electrical step 1 so ya car thought it wasn't in park, so u couldn't start it right?
yeah i found that to be a great reference source. http://groups.yahoo.com/group/nissans13/messages is a great sitefor S13, S14 &S15 drivers got a problem? go there first its got 66702 technical threads for nissan S13's |
actually I did that,I got the engine to crank I just cant get the engine to turn over or start
sleeping in traffic
k thats bit odd. probly cos u got a SR20 and i did it with a CA18 but i think thts not the case. maybe u bumped one of ur igition wires when u did the swap? thats got me stumpped. its been awhile since i did the swap so i can't really remember wat i did to the wiring besides the the loop and the reverse lights and i don't think i did any thing else to the auto computer. if u got it working can ya tell me wat ya did? thanx
yeah...It was actually an ignition wire...right on
Which ignition wire was it? i'm having the same problem.
Thanks |
Well Im actually ahving more problems im not even getting any spark now.... so I have no clue ive done EVERYTHING
Hows ur swap coming along...where do you live? Last edited by bboyt3nsk; 11-06-2004 at 11:24 AM. |
I live in california, Actually my car was running fine, this happened after I washed my engine , it just died no spark. It cranks but no spark.
Let me know how it goes for you. |
...are you?
You may have gotten water in your distributor cap, pull the cap and make sure all the contacts inside are dry.
cmon....were talkin about redtops...not girly engines with distributors!
#15 |
...are you?
Don't get to excited. might pop a blood vessel...
You know some sr20's came with a distributor, and some people put them in when they do the swap. And on the subject of girly engines here's some math: JDM engine imported into USDM market= low part availability and high price when needed part is available, now a sr20's D.I.S has more parts(that can and do fail) than the distributor system for the same engine, and less parts=less failure=less cost=less downtime,so I dont know if that makes D.I.S "girly", but it sure as hell does not make it preferential. |
#16 |
who should pop a blood vessel,lol
Its cool I like to joke around sometimes...dont take anything seriously if it sounds mean,chances its not. And I got another car and some money so its alright....I dont mind the downtime...and I assume youve got a KA I didnt know they did a conversion with the distributor....Whats the reasoning behind that? |
#17 |
...are you?
The reasoning behind using a distributor is: if you use one instead of the D.I.S you can use a ka24de E.C.U(with reprogramming) and a ka24de engine wire harness(with minor mods) to run the sr20det. Since not many people care about ka stuff, you could have a different E.C.U for each day of the week!
#18 |
wow i have been enlightened...thank you
