Turbo oil!
This is a discussion on Turbo oil! within the TECH Discussion Forum forums, part of the TECH Discussion category; When I started my engine....a substantial amount of oil came out from the turbo and leaked thru a leak in ...
Old 10-25-2004, 10:30 AM   #1
bboyt3nsk
Dinosuars=Jesus Horses
Turbo oil!
When I started my engine....a substantial amount of oil came out from the turbo and leaked thru a leak in the IC piping...is this normal for a 1st startup on an SR20DET redtop or is my turbo have a oil draining problem?
Old 10-25-2004, 04:45 PM   #2
pork_poney
give me your car.
pork_poney's Avatar
uhhh. i don't think that's right. i wouldn't start it back up until you get more info though, since i really have no idea. but, oil shouldn't come out of the turbo, to my knowledge, it should just move through it and return to the oil pan.
wait, you do have a return line to the oil pan, right?
pork_poney is offline   Reply With Quote
Old 10-25-2004, 05:15 PM   #3
GoukiS14
Subway Pervert FD
GoukiS14's Avatar
Location: Back in the U.S. but wishing he were back in Japan
how much is substantial? On my SR i had some oil leaking through, but it wasn't a crazy amount. Usually you will get some oil blowing into the intakes, a lot could mean you need a new turbo
GoukiS14 is offline   Reply With Quote
Old 10-25-2004, 05:42 PM   #4
DriftingNewbie
poser
DriftingNewbie's Avatar
somthing is really wrong. you might have a blown turbo because ihave heard a lot of people having this problem. good chance of it if there is alot of oil.
DriftingNewbie is offline   Reply With Quote
Old 10-26-2004, 02:13 AM   #5
f8ldzz
Drive the car around...
Does the exhaust smoke a lot???
Old 10-26-2004, 03:20 AM   #6
markeese180sx
markeese180sx's Avatar
same thing with my old s13...when i get near the redline in first and i shift and stop at a stop sign or somethin..theres smoke that comes from my exhaust and catches up to the car as it slows down..smells great..
Old 10-27-2004, 05:36 PM   #7
Warped
Flippin nutball!!!!
Warped's Avatar
Sounds like the seal is blow on the bearing that seperates the two sides of the turbo, it can be rebuilt but you must stop driving it before you cause serious damage to the turbo and your engine.
Old 10-27-2004, 07:11 PM   #8
GoukiS14
Subway Pervert FD
GoukiS14's Avatar
yeap that's what it sounds like to me
