This is a discussion on s15 headlights bolt on s13? within the TECH Discussion Forum forums, part of the TECH Discussion category; Searched but didnt find anything... im getting a 240 fastback soon and i want to do the conversion and im ...
Searched but didnt find anything... im getting a 240 fastback soon and i want to do the conversion and im wondering if the s15 headlights need special mounting or does it just bolt on (so i've heard)?
thanks in advance
noob
S15 S13 it is an obvious direct swap seriously have you ever seen a 240sx or s15? or heard of google, this took under 1 minute.... |
You should be able to find a lot of info on google.
like i said... so i've heard. if i knew it already, why would i ask? heard it from different people thats why i was cerious.
It's a direct bolt-on man...
You can do it in less than an hour...Actually, you should have asked this question in the n00b section. This is not a simple swap. You're better off sending your car to a bodyshop to do it... |
<.S][LVIA PSYKO.>
Location: where's ur location?if in canada i will come to ur house and cut you!!!
wow 1 hour damn...i saw a conversion it was like 2000usd.....it came with headlights and a bunch of other stuff.
to swap the front you will need of corse the s15 front hood and headlights. The fenders do not swap. There are however fiberglass fenders to do the swap with. You will also need the s15 headlight conecter and the hood hinges,headlightmounts. It takes like a day to do the full swap. Ive done it plenty of times and infact am now building a s15 truck out of my 180.
The s15 fenders DONOT match up anywhere on the 180 chassis. Fender holes, body lines everything is wrong. You will need to buy the fenders to do it. The S15 also came with HID headlights as well as normal bulb lights. Either one you have to splice the wires. |
#8 | |
1 Hour, were not making photos here. |
Junior Member
hmm i sense alot of sarcasim in here
my buddy in my town has the s15 front end on a s14 chassis....to top it off he did the rb25det motor swap.....and it has the Cwest front end ( s15)....and its RED with a black top...with a drag spoiler...with 3 piece Advan 3 spoke black and red wheels....
i will get some pics... but for the questions, NO it is NOT A DIRECT SWAP... go send your car to a body shop for paint and prep...you must rewire the headlights i believe too -J Mann |
