This is a discussion on Racing belts + no roll cage within the TECH Discussion Forum forums, part of the TECH Discussion category; I've done alot of reading about these things and how install them correctly. And that if they aren't right they ...
Schminking of gin
I've done alot of reading about these things and how install them correctly. And that if they aren't right they can kill you in an accident. I don't want to cage my car as the odds of a rollover are low and a cage is a pain with a 4 door. Sparco (I think) has a bar that attaches to the stock shoulder belt position and to the floor near the seat brackets. It spans the area between so you can loop or bolt the belts to it. I know that they'll never make one for my car, but it could be welded up fairly easy.Is this a good idea? Or am I wasting my time?
http://www.soloracer.com/rallyecross.html
these are street legal because on strap is supposed to releas and act like a 3 point if an impact happens so u are able to lean over if u do flip |
Schminking of gin
Cool, but what I was thinking was were they attach to? Some sort of roll bar is needed, right? I've seen them attached to the seat bolts and thats a no-no.
it dosnet matter where they can be mounted so long as its above 45 dgrees directly behind the drivers seat is what most say. lol i think their are a few diagrams on there too
TROLL HUNTER
Dude if you want a harness make sure its 3 in wide or theres really no point. Its a standard in racing.
But why wouldn't a harness be streetlegal?? Doesn't make sense to me. Anyways why would you want it to release like a 3 point?? So you can lean over when you flip?? So you can basically get whip-lash or pound your head into something? But I kinda understand if you don't have a rollcage, I guess you can lean forward and not have the roof crush you. But I highly doubt someone can react that fast, since you're flipping your body weight will fly in any direction, so its unpredictable. |
you're not leaning anywhere...you're just going to bounce off hte roof and get pushed out of the way, instead of bounce into the roof and smush when you are held in place.
Not the worst idea I've ever heard for sure. |
Schminking of gin
After market belts of any kind aren't street legal anywhere! They want you to use OEM belts. I'll feal real safe in my old muscle car with some crappy old style belt.
#8 | |
TROLL HUNTER
Schminking of gin
I agree. I don't think most cop with any sence will care.
Post idiot
Cops don't mind about racing harnesses in cars here in Europe, at least when they are safely attached to the body and/or something else like the Sparco bar (check it out at sparcousa.com).
#11 | |
Re: Racing belts + no roll cage
Attach the lap belts at either your stock lap belt locations or where the seat rails meet the frame. The shoulder belts can either be attached to the rear seat lap belt hardpoints or some other hardpoint (strut mount, shoulder belt, etc.) You keeping the rear seats in your sedan? |
The reason, or at least what I have heard, for harness not being legal is they restrict movement while inside the car. Making it harder to look behind you, according to the powers to be. They also say they are harder to get out of say if you fell in a lake and needed to un-buckle. I have also heard cops will not do anything if you have one but I guess you really just cant tell.
I don't know so much about racing harnesses, but I know that aircraft harnesses are far easier to get out of then standard seatbelts.
Pull the latch and your out. The straps sort of just flow off of you when you stand up. In a normal car seatbelt, you've gotta reach to hit a button, and then get the belt off of you and your arm. If I went into a lake, I'd definately rather have a jet harness than a belt... |
race cars tend to explode into firey balls of death more often that street cars. Therefore, racing harnesses are designed to be shed as quickly as possible. Just like aircraft belts, pull one lever and they fall away, simple as that!! i personally only trust sparco and simpson harnesses(i have sparco's in my car) stick with a 3 inch and youll be oh k
#15 |
like I said, I have just heard this, since I cant even drive yet I have no reason to be even read over
#16 |
Question:
Ok, would a racing harness actually help you in a normal street crash, or would it make it worse? (assuming the roof isn't crushed somehow, although it seems like they'd help in a roll-over) Or are they only good for keeping a race car driver in his seat, rather than safer in anything but a racing-esque crash? |
#17 |
trust me a race harness would definately help!, i was in a reck 2 weeks ago and the damn seat belt in the car popped off during the accident and my face slammed into the steering wheel and windshield, luckily my pretty face survived
(all 20 stitches are in my mouth), but if i had a race harness i would have been perfectly fine becuase it would have held me back against the seat and prevented me from slamming forward
#18 |
well..
it can go both ways if u are hit hard in the back they make it worse because your back takes all the force.. my friend was hit at 60mph in his RHD 14 and he blew 2 vertibrae(spelling) IN HIS BACK SO THEY HELP BUT THEY CAN HARM 2!
#19 |
Yo i have a toyota SUPRA 95 and i just put new sparco racing seats and and 3 point harness in it i found out the reason y u have to put a three point harness in ur car is bc it is used for offroading vehicles! and if u are worried about getting pulled over u wont cops dont care as long as u have a racing harnes in the back of ur car it goes around the passenger seat and the drivers seat it takes up no room at all! the only thing is that these harnesses ar not CHEAP! they range from 200 and up the cheapest i have seen is $230 that is all ik and i havent had a problem with the belt its comfrotable and everything iits been in my car for a month now!
#20 |
I had a friend in high school who put the 3" harness' in. He put the drivers in proper but not the passenger. He got into a front wreck at 50mph and his girl at the tome broke her clavical (collar bone). They help in some situsations and when worn proper but like everyone said not every crash/accident.
#21 |
I suggest looking at a autocross rule book to figure out how to safely mount a race harness with out a cage and loop.
#22 |
Yeah, if you're really worried about installing it correctly or not -- have a reputable shop (or somebody you really trust) do the work. This is a pretty like, serious investment because it could save your life.
